'List Members
I had a set of Ranger Cases cleaned last week and the shop stripped out the allen head brass oil line plugs trying to remove them. Is there a secret to removing these plugs for cleaning the oil lines?
Re: Ranger Question; Removing Brass oil line Plugs
David Stroud
'I watched a machinist friend tackle such a job once. He centerpunched the offending
plug and carefully drilled increasing sized holes in the plug till there was very little left
of the plug, then pried the threads of what was left of it into the center and unwound
the remaining threads.
Another technique might be to try a specific tool for the job. One such tool is called
an Easy Out. A little known trick for loosening very stubborn bolts is some home made
thread unlocker. Mix a couple of drops of Oil of Wintergreen (from the drug store)
in a bit of kerosene and let it soak overnight.
David Stroud Ottawa, Canada
C-FDWS Christavia
F-24 C-FDAE in restoration
C-FDWS Christavia
To: Fairchild Club
Sent: Friday, December 23, 2005 9:40 PM
Subject: [fairchildclub] Ranger Question; Removing Brass oil line Plugs
List Members
YAHOO! GROUPS LINKS
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.5/212 - Release Date: 12/23/05
Tom Downey
'--- In fairchildclub@yahoogroups.com, "david stroud"
they must be drilled.
I freeze the allen wrench, and heat the case with a hot airgun (never a
torch) when the frozzen wrench touches the plug it shrinks.'
Your first try at getting these out is your best chance, once stripped> in a bit of kerosene and let it soak overnight.
> C-FDWS Christavia
'Thanks for all the good suggestions for removing the brass allen plugs. Because my plugs were already stripped out I had to drill them out. It worked out vrey well and was a lot easier than I expected. I found that it works better if you drill the plug slightly off center and step drill out until you just reach the thread. This technique seams to relieve the pressure on the thread and allows you to screw the plug out instead of trying to peel the threads out. I tried it both ways and the off center method was far easier to remove.
Sent: Sunday, December 25, 2005 7:43 AM
Subject: [fairchildclub] Re: Ranger Question; Removing Brass oil line Plugs
> C-FDWS Christavia
YAHOO! GROUPS LINKS
