'It finally came to me as to why I've been having trouble bleeding the brake system and still seem to be getting air into the system.
The master cylinders in the 24's are installed at a +10 degree angle to the ground. Unless you can get the plunger/cup assembly to completely reach full travel, and maybe not even then, you will have a small pocket of air just above the outlet port.
What I did yesterday was to elevate the tail of the fuselage about 4 feet. 3.25 feet will bring the master cylinder to about a 0 degree tilt. Then feed brake fluid through the bleeder screw, up through the system to the master cylinder. I depressed the brake pedal a couple time break up the trapped air so it would either move out of the system and up the feed hose to the supply reservoir, or to suck it into the master cylinder reservoir on the return stroke. When the lower part of the master cylinder filled completely with brake fluid, I could then see the brake fluid start to come up through the compensator hole into the master cylinder reservoir.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
Bleeding Hayes Brakes
Return to “Yahoo Group Archives”
Jump to
- FAQs and Announcements
- ↳ Forum Notices, Comments, and Suggestions
- ↳ FAQs
- ↳ Fly-ins and Events
- Maintenance of Shared Components
- ↳ Engines and Props
- ↳ Radials
- ↳ Inlines
- ↳ Props
- ↳ Engine Accessories
- ↳ Landing Gear & Tailwheels
- ↳ Brakes and Wheels
- ↳ Instruments
- ↳ Lighting and Electrical
- ↳ Fuel Systems
- ↳ Airframe and Covers
- Fairchild Aircraft Types
- ↳ 24 Series
- ↳ Maintenance and Operation
- ↳ Checklists and Inspection Lists
- ↳ Fairchild and FAA/CAA Publications
- ↳ Service Bulletins
- ↳ Airworthiness Directives (ADs)
- ↳ 337s
- ↳ Fairchild 24 History
- ↳ Fairchild 24 - Wikipedia
- ↳ Military Primary Trainers - PT / M-62 Series
- ↳ Warbirds History
- ↳ Overview - Aircraft in Focus
- ↳ Kreider-Reisner Derived Aircraft
- ↳ KR Aircraft Co. - Wikipedia
- ↳ Other Fairchild Aircraft
- ↳ Model 45
- ↳ History - Wikipedia
- ↳ AT21
- ↳ Other
- Hanger Tales
- ↳ Experiences
- ↳ Destinations
- Suppliers and Service Providers
- ↳ Parts Sources
- ↳ Maintenance Shops
- ↳ Rebuilders
- ↳ Instruction
- ↳ Insurance
- ↳ Purchasing Assistance
- Classifieds
- ↳ For Sale or Trade
- ↳ Aircraft or Parts Sought
- ↳ Services
- ↳ Aviation Related Miscellany
- Yahoo Group Archives
