'________________________________________
Hello,
I am searching this big Oil filter Gasket for the Ranger. Internal diameter is
around 55mm. Is it something common ? If yes, where can I found these gaskets ?
Thanks.
JM Courtot
F-AZCI
See her at http://nostalgair.free.fr'
Re: Oil Fliter Gasket
danMichael
'On Tuesday, April 19, 2005, at 01:12 AM, j.courtot@free.fr wrote:
the main oil screen cover, I last purchased them from:
Fresno Airparts Co.
Chandler Field
520 West Kearney Blvd.
Fresno, CA. 93706
209-237-4863
They usually have a large advertisement in Trade-A-Plane. If someone
can recommend an alternate source, that would be great. Fresno wanted
several dollars per gasket and didnt accept credit cards, which makes
the transaction a little slow and/or complicated if you arent local.
:Dan
:NC81323'
If you are referring to the 2 1/8" AN900 copper / asbestos gasket for> I am searching this big Oil filter Gasket for the Ranger. Internal
> diameter is
> gaskets ?
Fresno Airparts Co.
Chandler Field
Fresno, CA. 93706
209-237-4863
:Dan
:NC81323'
'JM,
If you mean the Oil Screen, Fresno Airparts has them by the gross.
Aircraft Restoration & Repair
Kelly Airpark
Elbert, CO 80106
HM/Shop 303-648-0130
JamieTreat@direcway.com
Kelly Airpark
Elbert, CO 80106
Sent: Tuesday, April 19, 2005 12:12 AM
Subject: [fairchildclub] Oil Fliter Gasket
> Hello,
> diameter is
> gaskets ?
> Thanks.
> JM Courtot
> F-AZCI
