'Question,
I've only got about an hour flight time on my F24R since purchase.
I've been reading about other members tail wheel shimmy problems with
a lot of interest. I haven't experienced that trouble yet, but I think
it unusual that the problem is not mentioned on the takeoff run. Could
it be that the tail wheel is slightly cocked during landing. I mean,
what keeps the tire streamlined and centered as the tailwheel makes
contact, even though the pilot is imputing rudder corrections for
landing. Just curious.
R46368
Hanford, Ca.'
Re: Tailwheel shimmy...
'Tom:
roll, too, on hard-surface runways. As you note, it is far more likely
to be excited on landing since the tailwheel wont be perfectly aligned
with the track at touchdown unless there is no crosswind correction and
you are perfectly aligned with no drift. In my case, thats almost
never true!
Rebuilding the splines last year helped and I plan to install new
bushings soon.
mechanism to disable the steering and align the wheel when the strut is
extended. As long as the steering cam is engaged, the tailwheel steers
with rudder inputs. There are compression springs in the steering
cables where they attach to the mixer in the aft fuselage to
accommodate the shock of self-alignment as the tailwheel touches down.
These springs also allow you to move the rudder with the tailwheel on
the ground and make ground steering less precise. Almost all steerable
tailwheels have a similar arrangement: often the springs are mounted
externally right at the steering horns.
:Dan Michael
:NC81323'
Congratulations on your new plane!> I've only got about an hour flight time on my F24R since purchase.
As the shimmy on my 24 became worse, it started to occur on the takeoff> I've been reading about other members tail wheel shimmy problems with
never true!
bushings soon.
Nothing. Unlike, say, a typical Cessna nosewheel, there is no> I mean, what keeps the tire streamlined and centered as the tailwheel
> makes
:Dan Michael
:NC81323'
'If you can unload the tail wheel as you roll out it will usually stop the
shimmy. There is a detent pin which locks the tail wheel in trail when it is
unloaded
Sent: Sunday, April 03, 2005 1:22 PM
Subject: [fairchildclub] Tailwheel shimmy...
Question,
R46368
Hanford, Ca.
Terms of Service.
unloaded
Question,
R46368
Hanford, Ca.
Terms of Service.
CG is different on takeoff than landing.
Sent: Sunday, April 03, 2005 12:36 PM
Subject: Re: [fairchildclub] Tailwheel shimmy...
> Tom:
> never true!
> bushings soon.
>> makes
> :Dan Michael
> :NC81323
