Re: Ranger engine breakin procedure
longmere2
Post by longmere2 »
'I have about 450 hours on my engine, and to the best of my knowledge
it has always run on mineral oil. A mechanic suggested that I
switch to an AD oil. This has always been a no no. Any thoughts?
--- In fairchildclub@yahoogroups.com, Michael Denest
> One thing Mark did not mention is the oil type. We
> believe that 60 wt. (120 Grade) mineral is the best
> break-in oil to use. Run it for at least 25 hours or
> until the oil consumption goes down then drain it,
> check the screens and switch to 50 or 60 wt. AD
> (depending on climate). Works every time. 60 years
> ago, the only oil available was mineral and these
> engines were designed around that factor.
> Mike Denest
> --- mdaero1941@a... wrote:
> > Hey Bob, same here. What we have done in the past up
> > here is this. First we
> > adjust fuel and oil pressure. We like to see about
> > 60-65 lbs. on the oil. It
> > usually goes down about 5 lbs. after the first hour.
> > After about 10 hours we
> > will go back and adjust it to 55 lbs. We will do a
> > mag check at 1500 rpm also,
> > then shut down and cool off. Later on we'll go back
> > and run it up more time to
> > check things out, then fly. We only run it up for
> > about 10 to 15 minutes on the
> > ground. I'll do a shallow climb out to about 5,000
> > ft. (nice cool temp in
> > summer) then alternate the rpm from 2250 to 2300 for
> > ten minutes, then down to
> > 2100 for five minutes. Do this till the oil
> > consumption stabilizes. We have been
> > getting less then a quart to a quart and a half an
> > hour by this method. We
> > have been getting a few calls lately about
> > rebuilding Rangers, Dad just finished
> > his 51st rebuild for a fellow in Florida, and now we
> > have one that needs a
> > top overhaul that will go on a PT-26 in Illinois.
> > Anyway, it's been a good
> > discussion - hope things are nice in FL., it's about
> > 10 degrees here.
> > Mark Denest
> > [Non-text portions of this message have been
> > removed]
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - Helps protect you from nasty viruses.
> http://promotions.yahoo.com/new_mail
Post by Jamie S. Treat »
'You will be taking a chance breaking any sludge loose and causing damage.
I would not convert myself at this stage of the game.
Aircraft Restoration & Repair
Kelly Airpark
HM/Shop 303-648-0130
Sent: Friday, March 25, 2005 8:46 AM
Subject: [fairchildclub] Re: Ranger engine breakin procedure
>> Mike Denest
>> > 10 degrees here.
>> > Mark Denest
>> > removed]
>> Do you Yahoo!?
Bob Haas
Post by Bob Haas »
'I did that once along time ago, I think just after that I started buying 120
AD in 55 Gal drums. In those days oil drums were not too hard to get rid of.
That was before EPA!
From: Jamie S. Treat [mailto:jamietreat@direcway.com]
Sent: Friday, March 25, 2005 8:05 PM
Subject: Re: [fairchildclub] Re: Ranger engine breakin procedure
Kelly Airpark
>> Mike Denest
>> > 10 degrees here.
>> > Mark Denest
>> > removed]
>> Do you Yahoo!?
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
Terms of Service.
