Re: PT Rudder Hinge-to-Bracket Interference
Pete Crawford
Post by Pete Crawford »
'Hi Group,
I was fit-checking the rudder to the vertical stabilizer on my PT-26
before closing up the stab after rebuilding. One of the two holes of
the center rudder hinge (p/n 6623) would not go in far enough to
engage the hole of the stab bracket (p/n 66313). Examination showed
the hinge was hitting the bracket bolt. There are also witness marks
on the hinge which showed this interference was present when the
rudder was previously installed, but maybe not to this extent.
(Note - this rudder had never been installed on this fin.)
I measured the leg of the hinge which would not engage and there was
about 0.050" more material on that side of the hinge than on the side
which would engage, which is why one side would engage and the other
wouldn't.
A similar condition exists on the bottom hinge (same p/n) - bracket
(p/n 66316) combination, to the extent that the bracket hole was
slightly egged-out due to the hinge bolt being driven home during its
previous life! There were even thread marks in the bracket hole!
Has anyone seen this condition before? It must not be that uncommon
as all my hinges seem to suffer from the same disease. Any guidance
would be appreciated.
Pete Crawford'
Post by Michael Denest »
'Pete,
Have you tried to fit your rudder to another fin?
Sounds like something happened to the alignment in the
rebuilding process or the rudder hinge post may be in
question. Out of round bolt holes are not a good
thing! I've not seen the condition you are
describing, something is really wrong here. Can you
engage the bolts doing one hinge at a time? Refitting
parts from one aircraft can be tricky when fitting to
another aircraft, given the age of the parts. Sorry,
I can't offer more.
--- Pete Crawford wrote:
> Hi Group,
> the two holes of
> far enough to
> Examination showed
> also witness marks
> present when the
> this extent.
> fin.)
> than on the side
> wouldn't.
> p/n) - bracket
> bracket hole was
> bracket hole!
> be that uncommon
> Thanks,
> Pete Crawford
Do you Yahoo!?
All your favorites on one personal page ? Try My Yahoo!
http://my.yahoo.com'
Post by Curt Kinchen »
'Hi Pete, Other ideas that come to mind.
1. Have you tried flipping the stab bracket? Unlikely, but perhaps
it's not entirely symmetrical?
2. Is the hinge casting smooth? or is there a casting mark that
could be ground off to provide the clearance?
3. Could rotating the bracket bolt head do enough to provide
clearance?
4. Shouldn't require this, but consider going to a low profile
(NAS1104) or 12 point reduced head bolt for attaching the brackets.
5. The other thing that often crosses my mind is, if you're using
NOS surplus parts, were they surplussed because they were rejected
parts that weren't built per drawing? Not likely in this case, but I
wonder sometimes.
The vertical was just rebuilt on my PT before I bought it and I
remounted the rudder. I do recall them being close, but I'll take a
look and see if they make contact. I also have a spare rudder and
I'll see if there are any witness marks on those hinges.
--- In fairchildclub@yahoogroups.com, Michael Denest
> Pete,
> I can't offer more.
> Mike
> > Hi Group,
> > the two holes of
> > far enough to
> > Examination showed
> > also witness marks
> > present when the
> > this extent.
> > fin.)
> > than on the side
> > wouldn't.
> > p/n) - bracket
> > bracket hole was
> > bracket hole!
> > be that uncommon
> > Thanks,
> > Pete Crawford
> Do you Yahoo!?
> http://my.yahoo.com
clearance?
wonder sometimes.
> Pete,
> I can't offer more.
> Mike
> > Hi Group,
> > the two holes of
> > far enough to
> > Examination showed
> > also witness marks
> > present when the
> > this extent.
> > fin.)
> > than on the side
> > wouldn't.
> > p/n) - bracket
> > bracket hole was
> > bracket hole!
> > be that uncommon
> > Thanks,
> > Pete Crawford
> Do you Yahoo!?
> http://my.yahoo.com
