Re: Denver Fairchilds.....
Tom Mueller
Fuel flow troubles
Post by Tom Mueller »
'Recently drained off all the fuel in my F24R46, clear down to the
gasolater to facilitate installation of new fuel gauges, fuel
sending units and nos fuel shutoff valves. All went well, but I was
surprised when I couldn't get a fuel flow after installation. I put
10 gallons a side to the completely dry system, opened my new
shutoff vales an expected a gush at the gasolater. Not a drop.
Nothing I say, anybody got any ideas!
Hanford,Ca'
Re: Fuel flow troubles
Post by Jamie S. Treat »
You are getting the same effect as running one tank empty or both valves on
while flying, hence the AD Note.
Remove left cowl, open line entering carb and turn on one valve at a time.
It start with the left tank. Check both tanks for flow at carb. Retorque
line and it should start. Fuel flow at the gascolator will resume.
Sent: Friday, November 26, 2004 8:32 PM
Subject: [fairchildclub] Fuel flow troubles
> Tom
> Hanford,Ca
Aircraft Restoration & Repair
Kelly Airpark
HM/Shop 303-648-0130
> Tom
> Hanford,Ca
Kelly Airpark
> Tom
> Hanford,Ca
Tom Mueller
'Thanks for the response Jamie.
I'll do that in the moring, first thing. I don't understand the
reasoning behind all that for sure, I mean, you'd think it would
just qush at the gasolater being it so much lower than the tank, but
I'm starting at the carb like you suggest.
Thanx again,
Tom'
He got me last summer. I drained all the tanks for W&B. She would not drain
also. I even tried starting, would not prime. The cause is vacum draw
between the long tank lines.
Sent: Friday, November 26, 2004 9:07 PM
Subject: [fairchildclub] Re: Fuel flow troubles
> Thanx again,
> Tom
David Stroud
Post by David Stroud »
'Giday Tom, could you please say the source of the gauge / sender parts and
valves? p/n's if possible? Thanks.
David Stroud, Ottawa, Canada
Christavia C-FDWS
F24 C-FDAE in restoration
Sent: Friday, November 26, 2004 10:32 PM
> Tom
> Hanford,Ca
Tom Mueller
'David,
I got the fuel valves from member, Jim Chybicki, I "think" he said
he had one set left. Phone (847) 530-4377.
Also got Stewart-Warner matching sender/gauge units, with the
senders being S/W pn F385-C, and the guage S/W pn 82211.
I got these part numbers from other long time members.
They are a real hassle to install.... basically you're installing a
fuel tank sending unit designed to mount on top of the tank so,
being you're mounting them on the bottom, the float arm has to be
bent every which way to get the correct readings. I bent mine to
read "empty" with still 5 gals left per side. It's nice to have them
working, Of course "sticking" the tank is always the final word.
I say again, it is a hassle,
Hanford,Ca'
danMichael
Post by danMichael »
'All:
Can someone explain the precise problem that restricts the 24 to
running on one tank at a time? I had thought it was caused by the air
pressure at the cap vents during flight being lower than ambient
pressure at the carburetor. If both tanks are selected and a tank were
to go dry, the head pressure of the full tank would cause it to
crossfeed to the empty one rather than supply the carburetor. Is this
right?
I talked to Paul Conn at Oshkosh. He modified the fuel system in his
(amazingly beautiful!) 24W to provide a pressure vent to each tank
(similar to most single engine Cessnas). He says this allows him to
safely operate with both tanks selected.
> time.
> Retorque
Isnt it a certification requirement that the fuel system prime if a
tank runs dry and another source selected?
> valves on
Is this an AD? I couldnt find it on the FAA AD site.
Curiously yours,
:Dan
:NC81323'
'Dan,
AD note 46-40-01 is the applicable AD note. SB 44-7-C is the Fairchild
Service note. You must install placard near both fuel tank valves which
states "Operate on one tank only at a time only" An accident, drove this AD
note.
All the AD notes are on the Fairchild CD ROM.
If you run a tank dry, you will/should be able to switch to tank containing
fuel and you will run normally. I happened to me this past summer. I ran the
Ranger hard for one hour on a 1/2+ tank at full throttle trying to out run a
thunderstorm. That sucker can burn some fuel at full throttle. When that
Ranger runs short on fuel, it stops right now, makes your heart beat a
little faster. F-24 is not a good glider at 14,000 feet denisty alt.
I have also found the following. I normally taxi on the low tank. Just prior
to takeoff I switch to the fullest tank. I modified my procedure. "After
this happend twice with the tail up, just prior to lift-off". I make sure I
run the tank on the fullest for at least two minutes prior to takeoff. There
must be trapped air in the line between the full tank and gascolator. That
air gets to the carb just as you have the tail up and the engine quits cold.
Makes for an interesting high speed taxi. Never does it in the air, just on
the ground.
As far as modifing, it can be done. But you will still be required to comply
with the AD note, which means placard and operation on one tank only. The
only way to get around that is contact the Eng office of the FAA and provide
engineering data that will satisfy the FAA that you have found a better way
of satisfing the AD Note. So, Paul is illegal unless he does the previous.
I wish somebody good luck, I have been working with the FAA in FTW in regard
to the Gear AD 47-50-09 note. The SB 41-8 states if you perform a NDI by
magnaflux you are no longer required to perform the recurring AD note. Those
words never got into the AD note due to the factory went out of buisness for
supporting F-24s. Also the SB does not call out the fueslage fittings nor
the 24R46 or 24W46. The later models had the heavy gear installed. So, the
FAA AD note does not match the Fairchild SB. But nobody in the FAA will
stick there neck out since it is a libility issue.
Kelly Airpark
Sent: Saturday, November 27, 2004 12:26 PM
Subject: Re: [fairchildclub] Fuel flow troubles
> All:
> right?
>> time.
>> Retorque
>> valves on
> Curiously yours,
> :Dan
> :NC81323
