I made my spacers of a steel tube fitting the bolt.> Hellå
I also found that the yoke differs in dimension so again it is best to make them fit your 10´yoke. The bushings must also fit the seals you have and those differs to.
The 10´tail wheel was at the time a army speck, UC 61, so I don´t think there is a STC for it. John Berent has probably all the drawings.
paul
-------------------------------------------------> Från: "m77mb"
> Datum: 2004/11/18 Thu AM 12:27:35 CET
> Till: fairchildclub@yahoogroups.com
> Ämne: [fairchildclub] tailwheel spacers for 10"SC tailwheel
> I need 2 spacers for the 10' sc TAILWHEEL. These fit outside the
> bearings between the tailwheel and the yoke. The axle slides through
> them. Does anyone know where I can get them? Also , even though I am
> attempting to put back the original style of tailwheel and tire ( I
> have a new tailwheel, tire and tube) there is a non-standard
> tailwheel already on the plane which has a 4" wheel and 2.8/2.5 x 4
> tire already. Can't find any STC for this conversion. Is there one?
> Thanks
> Donis B. Hamilton
> NC81311
> 1946 F24R-46
WebMail från Tele2 http://www.tele2.se
