Re: Microair and others
ranger440c5
Microair and others
Post by ranger440c5 »
'While on the subject of the Microair radios I have a question
regarding these and similar items. For those out there with
regulation prowess and a penchant for proper paperwork.....
Can someone explain how the TSO rating on these appliances impacts
installation? EXACTLY what this means as far as can it be legally
installed in normal catagory aircraft? How is this getting done? I
understand the TSO is there to assure the item meets certain criteria
for the given appliance and as such if an item is not TSO'd (Microair
products are not) then is it legal for installation in a normal
standard aircraft? Smaller items such as gages that are not TSO'd are
usually intended for experimental applications. It appears to me that
this is a quasi problem, a real gray area that could go either way
depending on the FSDO. I get the feeling that our FSDO leans toward
the direction of NO, if it is not TSO'd then the only way it's going
in the plane is by field approval. I have seen lots of these non
TSO'd items in planes and I wonder if anyone has actually processed
this correctly. Did they simply throw it in there and fill out a
337? It goes through the FSDO w/o any scrutiny? I have asked many
IA's about this and get responses from shoulder shrug beats me to I
dunno. An item to relate to is seatbelts. I don't think there is an
IA in the world that would install or sign off an airplane (non-
experimental) with out TSO'd belts. They all seem to know about this
one, but what about the avionics? I have avoided these non-TSO'd
products to bypass any of the above concerns as it appeared to be the
only surefire way to stay clear of unforseen pitfalls. If this matter
were definitively put to rest, it would certainly open up some
alternative sources.
How about it? EXACTLY how does this work?'
Post by Jamie S. Treat »
'All,
As an IA I do it this way.
If it has an TSO or FAA/PMA then it can go legally on the aircraft. It may
or may not require a FAA based on a STC. At a minium it will require
logbook, W&B, and equiplist update.
If it is not an TSO or FAA/PMA approved item, it will require at the minium.
FAA 337, field approval, with continuation of airworthness to be completed,
any and all data the FAA may need to accompany the FAA 337 for block 3
endorsement.
Take for instance the installation of a Non FAA/PMA approved nor TSOd engine
preoiler. I am doing three of them right now. I will submitt a unsigned FAA
337 completed with all the data including photos, tech data, and drawings to
the FAA for block 3 approval. If approved I will then purchase hardware and
install. I as the IA will return to service after install.
Point is, you must work with your FAA office and work out the details prior
to purchase and install. Providing them the correct data in a logical sense
has never let me down in 25 years.
Please feel free to call me for assistance. Advice is free.
Aircraft Restoration & Repair
Kelly Airpark
HM/Shop 303-648-0130
Sent: Wednesday, September 15, 2004 8:55 AM
Subject: [fairchildclub] Microair and others
ranger440c5
'Thanks for the response.
So to install a Microair you need a "field approval". The proceedure
you described for this is EXACTLY how to handle such operations. I
have run this route on many blk 3 approvals and it works well. Well
done.
The question lies in it's necessity. I have received a response from
a member stating that pt91 operations require no TSO. Welllllll, yes
and no. The ELT has to be TSO-C91a and this is in pt 91 ops. So pt 91
does require TSO'd equipment. I think the answer to this is a little
between the lines. Though not clearly stated, we must equate
that "approved articles" (ref pt 21) means it meets the applicable
TSO for that article. In other words, to be "previously approved by
the agency" it meets a TSO? Therefore TSO'd. If installing an article
in a normal catagory aircraft, if not supplied by the aircraft
manufacturer, then must be previously approved(TSO) by the Agency
(FAA). Based on this I am inclined to agree with you Jaime(and our
local FSDO).
The jist is this, for owners who want to have an item installed, the
lesscostly non-TSO item may cost more when installed and paperwork is
processed and there is a downtime factor while awaiting possible
delays in the approval process. Remember what Jaime stated fill out a
337, acquire supporting data, apply for approval, THEN order
hardware, install, and lastly file said paperwork.
So how many of the Microair owners out there have a 337 with blk 3
signed and dated BEFORE the IA signed and dated blk7?
> All,
It may
require
the minium.
completed,
block 3
> endorsement.
TSOd engine
unsigned FAA
drawings to
hardware and
details prior
logical sense
> Kelly Airpark
> Elbert, CO 80106
> From: "ranger440c5"
criteria
(Microair
are
that
toward
going
processed
I
an
this
the
matter
> > Yahoo! Groups Links
rangerrobertmn
Post by rangerrobertmn »
'Hello Ranger440c5,
I have a Microair Electronics tranciever installed in my Fairchild
24. I have a 337 on which Block #3 is signed and dated 4/10/2000,
and Block #7 is signed and dated 4-21-00.
1939 Fairchild 24 K
Stillwater, MN
--- In fairchildclub@yahoogroups.com, "ranger440c5"
proceedure
Well
> done.
from
yes
91
little
by
article
> local FSDO).
the
is
out a
3
> wrote:
> > All,
aircraft.
> It may
> require
> the minium.
> completed,
> block 3
> > endorsement.
> TSOd engine
> unsigned FAA
> drawings to
> hardware and
> details prior
> logical sense
> > Kelly Airpark
> > Elbert, CO 80106
> > From: "ranger440c5"
> > To:
impacts
legally
done? I
> criteria
> (Microair
TSO'd
> are
me
> that
way
> toward
> going
non
> processed
out a
many
to
> I
is
> an
(non-
about
> this
TSO'd
be
> the
> matter
> > > Yahoo! Groups Links
ranger440c5
'Good morning Bob,
Apparrently your mechanic/IA believes also that it required
approval. Your Microair is part of an approved INSTALLATION.
However, if it poops out won't it need to be approved again? The blk
3 sign off is good for that single installation only using the exact
parts only for the initial installation is it not? So if some of
those parts were not previously approved and they are to be replaced
don't they need to be approved again? This would seem the case since
if a radio is non-TSO'd there are no Aviation Agency related
specifications it is required to meet and therefore no assurance of
part to part consistency other than the manufacturer's own (in this
instance, an Australian firm, who is holding their feet to the fire?).
--- In fairchildclub@yahoogroups.com, "rangerrobertmn"
> Hello Ranger440c5,
> Bob Waldron
> 1939 Fairchild 24 K
> Stillwater, MN
> proceedure
I
> Well
> > done.
> from
> yes
pt
> 91
> little
applicable
> by
> article
our
> > local FSDO).
> the
paperwork
> is
> out a
> 3
> > wrote:
> > > All,
> aircraft.
> > It may
> > require
at
> > the minium.
be
> > completed,
> > block 3
> > > endorsement.
nor
> > TSOd engine
> > unsigned FAA
and
> > drawings to
> > hardware and
> > details prior
> > logical sense
> > > Kelly Airpark
> > > Elbert, CO 80106
> > > From: "ranger440c5"
> > > To:
> impacts
> legally
> done? I
> > criteria
> > (Microair
normal
> TSO'd
> > are
> me
> > that
either
> way
> > toward
it's
> > going
> non
> > processed
> out a
> many
me
> to
> > I
> is
> > an
> (non-
> about
> > this
> TSO'd
to
> be
> > the
this
> > matter
> > > > Yahoo! Groups Links
rangerrobertmn
'Hello Ranger440c5,
I fly for fun. I truely enjoy flying the Fairchild. My IA tries to
keep my airplanes legal, and I try to keep his couputer running.
Life is great. I don't have the slightest worry about what to do
when my wonderful radio 'poops out'. It is something that I will
have to address at that time.
I have great admiration for the AUSTRALIANS at MicroAir. The only
time that I dealt with them the bent way over backwards for me. I
am VERY impressed by the people in the Microair company. I would
not hesitate to buy another product from them for another airplane.
Happily flying around Stillwater MN and communicating clearly on my
Microair
1939 Fairchild 24K
1940 Taylorcraft BL-65
1941 Piper J-3 F65
> Good morning Bob,
blk
exact
replaced
since
of
this
fire?).
> wrote:
> > Hello Ranger440c5,
Fairchild
4/10/2000,
> > Bob Waldron
> > 1939 Fairchild 24 K
> > Stillwater, MN
> > proceedure
operations.
> I
> > Well
> > > done.
response
> > from
Welllllll,
> > yes
So
> pt
> > 91
> > little
> applicable
approved
> > by
> > article
Agency
> our
> > > local FSDO).
installed,
> > the
> paperwork
> > is
possible
fill
> > out a
blk
> > 3
> > > wrote:
> > > > All,
> > aircraft.
> > > It may
> > > require
require
> at
> > > the minium.
to
> be
> > > completed,
for
> > > block 3
> > > > endorsement.
> nor
> > > TSOd engine
a
> > > unsigned FAA
> and
> > > drawings to
purchase
> > > hardware and
the
> > > details prior
a
> > > logical sense
> > > > Kelly Airpark
> > > > Elbert, CO 80106
> > > > From: "ranger440c5"
> > > > To:
question
> > impacts
> > legally
> > done? I
certain
> > > criteria
TSO'd
> > > (Microair
> normal
not
> > TSO'd
> > > are
to
> > me
> > > that
> either
> > way
leans
> > > toward
> it's
> > > going
these
> > non
> > > processed
fill
> > out a
asked
> > many
beats
> me
> > to
> > > I
there
> > is
> > > an
> > (non-
> > about
> > > this
> > TSO'd
appeared
> to
> > be
> > > the
> this
> > > matter
some
> > > > > Yahoo! Groups Links
Buell Powell
Post by Buell Powell »
Sent: Saturday, September 18, 2004 6:42 PM
Subject: [fairchildclub] Re: Microair and others
> Hello Ranger440c5,
> Microair
> Bob Waldron
> 1939 Fairchild 24K
> 1941 Piper J-3 F65
> wrote:
> > Good morning Bob,
> blk
> exact
> replaced
> since
> of
> this
> fire?).
> > wrote:
> > > Hello Ranger440c5,
> Fairchild
> 4/10/2000,
> > > Bob Waldron
> > > 1939 Fairchild 24 K
> > > Stillwater, MN
> > > proceedure
> operations.
> > I
> > > Well
> > > > done.
> response
> > > from
> Welllllll,
> > > yes
> So
> > pt
> > > 91
> > > little
> > applicable
> approved
> > > by
> > > article
> Agency
> > our
> > > > local FSDO).
> installed,
> > > the
> > paperwork
> > > is
> possible
> fill
> > > out a
> blk
> > > 3
> > > > wrote:
> > > > > All,
> > > aircraft.
> > > > It may
> > > > require
> require
> > at
> > > > the minium.
> to
> > be
> > > > completed,
> for
> > > > block 3
> > > > > endorsement.
> > nor
> > > > TSOd engine
> a
> > > > unsigned FAA
> > and
> > > > drawings to
> purchase
> > > > hardware and
> the
> > > > details prior
> a
> > > > logical sense
> > > > > Kelly Airpark
> > > > > Elbert, CO 80106
> > > > > From: "ranger440c5"
> > > > > To:
> question
> > > impacts
> > > legally
> > > done? I
> certain
> > > > criteria
> TSO'd
> > > > (Microair
> > normal
> not
> > > TSO'd
> > > > are
> to
> > > me
> > > > that
> > either
> > > way
> leans
> > > > toward
> > it's
> > > > going
> these
> > > non
> > > > processed
> fill
> > > out a
> asked
> > > many
> beats
> > me
> > > to
> > > > I
> there
> > > is
> > > > an
> > > (non-
> > > about
> > > > this
> > > TSO'd
> appeared
> > to
> > > be
> > > > the
> > this
> > > > matter
> some
> > > > > > Yahoo! Groups Links
Buell Powell
'Hi Bob,
I totaly agree- I also so some work for my IA in exchange
for helping to keep my airplane legal (mostly on his Champ). I asked about
some of the legal problems that came up on the e-mails and he thinks that I
should be able to use the microair without too much hassle-probably a 337
form. I really like the way it looks and all I need is a com radio-I have a
hand held GPS.
Thanks again for the information,
Buell Powell
1941 T/craft
1946 F24 (someday)
> Hello Ranger440c5,
> Microair
> Bob Waldron
> 1939 Fairchild 24K
> 1941 Piper J-3 F65
> wrote:
> > Good morning Bob,
> blk
> exact
> replaced
> since
> of
> this
> fire?).
> > wrote:
> > > Hello Ranger440c5,
> Fairchild
> 4/10/2000,
> > > Bob Waldron
> > > 1939 Fairchild 24 K
> > > Stillwater, MN
> > > proceedure
> operations.
> > I
> > > Well
> > > > done.
> response
> > > from
> Welllllll,
> > > yes
> So
> > pt
> > > 91
> > > little
> > applicable
> approved
> > > by
> > > article
> Agency
> > our
> > > > local FSDO).
> installed,
> > > the
> > paperwork
> > > is
> possible
> fill
> > > out a
> blk
> > > 3
> > > > wrote:
> > > > > All,
> > > aircraft.
> > > > It may
> > > > require
> require
> > at
> > > > the minium.
> to
> > be
> > > > completed,
> for
> > > > block 3
> > > > > endorsement.
> > nor
> > > > TSOd engine
> a
> > > > unsigned FAA
> > and
> > > > drawings to
> purchase
> > > > hardware and
> the
> > > > details prior
> a
> > > > logical sense
> > > > > Kelly Airpark
> > > > > Elbert, CO 80106
> > > > > From: "ranger440c5"
> > > > > To:
> question
> > > impacts
> > > legally
> > > done? I
> certain
> > > > criteria
> TSO'd
> > > > (Microair
> > normal
> not
> > > TSO'd
> > > > are
> to
> > > me
> > > > that
> > either
> > > way
> leans
> > > > toward
> > it's
> > > > going
> these
> > > non
> > > > processed
> fill
> > > out a
> asked
> > > many
> beats
> > me
> > > to
> > > > I
> there
> > > is
> > > > an
> > > (non-
> > > about
> > > > this
> > > TSO'd
> appeared
> > to
> > > be
> > > > the
> > this
> > > > matter
> some
> > > > > > Yahoo! Groups Links
ranger440c5
'Evening Bob,
To that end, as it should be! I believe I have found the definitive
solution. I haven't figured out how to fly yet. I merely flop about
like a fish out of water and meander aimlessly like a drunken
sailor.I am sure my flight path provides hours of entertainment for
the hapless controller who unwittingly tracks me. I once had a GPS
but scared my self when I had to expand the little HSI path to
display 20 miles either side of programmed flight path to contain my
actual plot trail. It didn't look that bad when the moving map was
scaled out to 300 miles. I like to think of this as an aerial version
of what sailors call tacking, and I think they regard tacking as a
skill that requires years to master. Man, I'm way ahead on that one.
This can be attributed to establishing a course according to the
direction the cows are heading. It seems there is a conspiracy as no
2 herds have the same destination, therfore I have to do a bit of
interpolation. The most disturbing problem is my 24 is so far out of
rig the cows can out run me to the loafing shed. We won't get into
holding altitude.....1 axis at a time please.
> Hello Ranger440c5,
to
> Microair
> Bob Waldron
> 1939 Fairchild 24K
> 1941 Piper J-3 F65
Buell Powell
'I suppose a lot of pilots these days would think that without using
a GPS, VOR, or Whatever, you might as well be floping around like a fish. I
would have to disagree. I think it takes more skill and is much more
rewarding to use the old nav skills like dead reckoning and pilotage. My
father was an instructer before he joined the Air Core's war training
program in 1942. I am luckey because when he visits we always go for some
trips in my T/craft. His most advanced piece of nav. equipment is an old
military E6B computer. Somehow though he can figure the wind speed, wind
direction, and true course without using it. He is also giving me
instructions on flying IFR with the only instuments I have in my
T/craft-airspeed, ailtimeter, rate of climp, and turn indicator, just in
case I find myself in bad weather. He thinks the GPS takes the fun out of
flying and I sort of agree. My wife and I are planning about an 800 mile
trip next week and half the fun is the map work etc. Besides it takes the
trip more enjoyable for the wife if she can help me look for checkpoints and
mark the times to figure groundspeed instead of just looking out the window
in boredom.
Well, whatever type of flying you like to do. Be safe and enjoy it. We
are really lucky to live where we can still just flop around like a fish if
we want to.
Buell Powell
PS
Thanks again to everyone for the information about the radios. If I
do end up with a microair radio I am going to take Jamie's advice about
checking with the FAA first and not worry to much about it after it is
installed.
Sent: Wednesday, September 22, 2004 9:15 PM
> Evening Bob,
> wrote:
> > Hello Ranger440c5,
> to
> > Microair
> > Bob Waldron
> > 1939 Fairchild 24K
> > 1941 Piper J-3 F65
