'gent's...
I'm new to this chat group..
I would like to ask your advice on how to obtain value info on an old
prop that I have from my fathers estate.
Here is what I do know:
Wooden Prop
MFG logo on it : made by S&S Aircraft LTD, Winnipeg, Canada
following info burned into hub:
Year of MFG 1942
Diameter: 85 Inch
Pitch: 61
Ranger-644C5
two other numbers stamped: a SSS220D & SERW1067
This Item was actually used on a Fairchild Cornell trainer Circa 1942
(suspect it was a PT-23)
I am trying to determine what the actual resale value would be. I
Any suggestions?
I also know that this item was used at a training field in
Ontario, Canada. My dad was a flight mechanic there during the early
40's.
Your help would greatly be appreciated
Regards
Tim (from Canada)'
Re: Vintage prop question PT-23 Cira 1942
cliffmccluney@webtv.net
'You have a PT-19/26 prop for a Ranger engine. The value will depend on
whether it is glued with Resorcinol glue or not. You can tell by
looking at the laminations to see if the glue has a reddish brown color
and is fanned out into the wood pores. Props not glued with the resin
glue will sometimes delaminate when moved to another climate. I have
had two do it.
regards,
Cliff McCluney
Kerens, TX.'
had two do it.
regards,
Cliff McCluney
Kerens, TX.'
john smith
'Thanks for the tip.
had two do it.
regards,
Cliff McCluney
Kerens, TX.
To visit your group on the web, go to:
Post your free ad now! Yahoo! Canada Personals
had two do it.
regards,
Cliff McCluney
Kerens, TX.
The Archive_Guy
'Thanks for the tip
cliffmccluney@webtv.net wrote:You have a PT-19/26 prop for a Ranger engine. The value will depend on
had two do it.
regards,
Cliff McCluney
Kerens, TX.
had two do it.
regards,
Cliff McCluney
Kerens, TX.
