'Things never seem to go to plan on my airplane. The problem is that I
am having to adapt a motor, mount and ancilliaries to fit and there
are no drawings or other installations to copy.
As you may remember I am putting a 145 Scarab onto a Rearwin
Cloudster. I know this is not a Fairchild but the best source of
information I have is here on the forum as some of my installation is
pure F24.
I bought the airplane without a motor as that had been taken for a
WW1 replica (don't get me started on that . . .) and it had been a
145 Warner so I managed to find another and after much searching of
parts and far too much money, I got it rebuilt. Halfway through this
I found that there are long sump and short sump versions and the one
I had was different to the one that came off. Typical. Not only is
the sump different bit the motor uses a different mount. The shot
sump version has a full ring mount that is flattened on the bottom
and the long sump, that I have, has a horseshoe mount. Various group
members helped me get that one sorted but I had to re-engineer my
mount to make it fit.
When I fitted the motor I found that one od the mount bracing tubes
fouled the mixture control and so I had a phenolic spacer made to
lower the carb a little so this would clear. Far easier than trying
to adapt the mount at that stage. (We had to weld up the mount before
the motor had been rebuilt otherwise we might have found this but
there were not many places we could actually put the bracing tube and
it had to be there).
So, all that was sorted, the motor was on and I have been connecting it up.
I managed, as some of you will have read, to track a hot air box down
from Harman Dickerson. This is brand new, never been on an airplane
and I tried it on the motor over the weekend. Guess what? It doesn't
fit.
It fouls the exhaust and rocker covers. I don't think that this is
due to the carb being lower as if it had not fouled the rocker cover
it would have been fouling something else on the cylinder and even
then it would still have hit the exhaust, only further up.
So, the question for the Warner Gurus here is: Have you had
experience with this. Could I just have the wrong type of heat box
(for example would mine have fitted the short sump motor) or can
anyone think of a way around this. I think my alternatives are to
have a heat box made to fit the space which means a lot of messing
around and I don't want to waste the time as I want to go fly. I only
have a few connections to make on the motor, the baffles to fit and a
cowling to finish and I can have this ready for flying. This is so
frustrating!
So, any suggestions gratefully received. Include your phone number
and time zone and I might well call you to talk about it.
Melvyn Hiscock'
Re: Cloudster collaborating
ranger440c5
'Mr. Hiscock,
Didn't your Cloudster come with a KenRoyce originally? So what you
are doing is a restoration of a previous alteration? Hmmm......
challenging indeed! We all know how most previous alterations were
done with the utmost in planning, engineering, and skillfull
installation, right?
None-the-less, perhaps what you need is a hot air exchanger as
earlier Wrights,Kinners,Warners etc. While a tad complex, these
installations are bit more flexible when it comes to placing
components.
The final solution is near at hand, you may already be aware of it.
Keep throwing money at it and it will work! Hang in there, Cloudsters
are neat ships.
--- In fairchildclub@yahoogroups.com, Melvyn Hiscock
components.
are neat ships.
I> Things never seem to go to plan on my airplane. The problem is that
is> am having to adapt a motor, mount and ancilliaries to fit and there
this> pure F24.
one> I found that there are long sump and short sump versions and the
group> I had was different to the one that came off. Typical. Not only is
before> members helped me get that one sorted but I had to re-engineer my
and> the motor had been rebuilt otherwise we might have found this but
connecting it up.> it had to be there).
down>
doesn't> from Harman Dickerson. This is brand new, never been on an airplane
cover> fit.
only> it would have been fouling something else on the cylinder and even
a> have a few connections to make on the motor, the baffles to fit and
'> cowling to finish and I can have this ready for flying. This is so
> frustrating!
> Melvyn Hiscock
Melvyn Hiscock
'--- In fairchildclub@yahoogroups.com, "ranger440c5"
Ken Royce, it was converted from an 8090 whilst still on the line.
It got a 125 Scarab in 1957 and the 145 in 1968. I have now done
most of the work.
a so-called toilet seat mount. Mmmm, nice. Since then it has had
the mount properly stressed, rebuilt, new rubbers sourced, and
that is just the mount. The rest has been torn down and
completely rebuilt.
on the air box did not line up so I measured them and found the
carb had been fitted (not by me!) 90 deg. out from what it should!
Before I left tonight I was able to refit the carb with the box tacked
into place and without the phenolic spacer (more money gone!)
and it all fits. Mind you I know have to buy a new throttle cable as
the one I had bought no longer fits. Everything esle is fine
though.
Thanks for your help,
Melvyn Hiscock'
what you> Mr. Hiscock,
You could say that. Mine was the first Cloudster to have the 120> are doing is a restoration of a previous alteration? Hmmm......
> challenging indeed!
most of the work.
Yeah! Originally the Warner was fitted to a 3/8in plywood adapter,> done with the utmost in planning, engineering, and skillfull
completely rebuilt.
as> None-the-less, perhaps what you need is a hot air exchanger
these> earlier Wrights,Kinners,Warners etc. While a tad complex,
it.> installations are bit more flexible when it comes to placing
> components.
Cloudsters> Keep throwing money at it and it will work! Hang in there,
Thanks. As it happens I found the problem today. The bolt holes> are neat ships.
though.
Melvyn Hiscock'
