Re: E Gap
Bob and Dot Haas
E Gap
Post by Bob and Dot Haas »
'Good morning Ranger Drivers, Where can I find the E Gap
clearance for a Bendix Scintilla SB6RN-8 or what should it be? Bob
Hayes Wheels
Post by Michael Denest »
'My dad has two Hayes 7.50 x 10 wheels available for
either the PT or F24. Both are in good condition.
$125.00 each. Call Joe at 610-399-7028.
Do you Yahoo!?
Find out what made the Top Yahoo! Searches of 2003
http://search.yahoo.com/top2003'
pt19b2001
Re: E Gap
Post by pt19b2001 »
'Bob,
There is not an E-gap to set on these mags. They should be set so
that the points just begin to open when the mark on the large gear
aligns with the fixed mark when looking through the timing window.
The best way to accomplish this is to place a .0015 shim stock
between the contacts, then while slightly pulling on the shim stock
turn the mag drive shaft. When the shim moves the mark on the gear
should be lined up with the fixed mark. If not adjust the gap with
the points attachment screws. This information was found on my CD
under Ranger Engine service instructions L-440-1,3,5 page 24 and 25.
Thane Riffle
--- In fairchildclub@yahoogroups.com, "Bob and Dot Haas"
Gap
Bob and Dot Haas
Re: E Gap
'Hey Thane! I dug out my trusty PT 19 series CD and it
refused to start in my computer. I had talked to you some time ago when
I first got it, you told me to send it back, but I got it working on
another computer and just spaced it out. The dimension on the mag points
is no less than .012 and no greater than.025. I'll save the
Email and get back to you . Thanks Bob
Sent: Tuesday, December 30, 2003 2:13 PM
Subject: [fairchildclub] Re: E Gap
Bob,
Thane Riffle
Gap
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Jamie Treat
Re: E Gap
Post by Jamie Treat »
'Bob,
E-Gap not a factor, no specific requirement, all mags will be different. I
have always used cellophane to set point opening. I will send you the
manual to your email account.
Section IV, Page 3F-369 and page 3F-377 of manual.
To: "Fairchildclub@yahoogroups. com"
Sent: Tuesday, December 30, 2003 7:32 AM
Subject: [fairchildclub] E Gap
> Your use of Yahoo! Groups is subject to:
