Re: Ranger Engine Mag P-Leads
'Should the shielding on the p-lead wires be grounded on both ends,
both the mag end and the mag switch end ?'
'Hello,
I hope someone who REALLY knows, will reply to your question. If they
don't, I believe that NO shielding wire should ever be grounded on BOTH ends
of the wire. Doing so, makes the shielding an antenna for stray electrical
noise, which is exactly opposite of what you are trying to do by installing
the shielding. I hope someone who REALLY knows, will reply.
1939 Fairchild 24K
Stillwater, MN
1939 Fairchild 24K
Stillwater, MN
Sent: Monday, December 15, 2003 1:07 PM
Subject: [fairchildclub] Ranger Engine Mag P-Leads
'I can't say one way or the other about grounding the leads at one or both
ends. I have seen on the Bendix SF4RN-8 (Similar to the SF6RN used on
Rangers) that the P lead can be grounded at the magneto. And some of the
magneto switches have something like a cover around the back side of the
switch so that a grounding braid could be clamped to it. The cover on the
back of the mag. switch had a large diameter that fit around the rear body
of the switch and the smaller portion was about the diameter of a dime. One
thing that I have done in recent years, is to use a Radio Frequency (RF
filter Capacitor) on the magneto P lead output connection and ground, at the
magneto.
You could try grounding both ends. If that doesn't work. Remove the one on
the magneto end, and try it again. It would be easier to cut off an
unwanted shield lead, than to add one(2).
magneto.
Sent: Monday, December 15, 2003 7:36 PM
Subject: Re: [fairchildclub] Ranger Engine Mag P-Leads
> Hello,
ends
electrical
installing
> Bob Waldron
> 1939 Fairchild 24K
> Stillwater, MN
> From: "fredakumpf"
> To visit your group on the web, go to:
> Your use of Yahoo! Groups is subject to:
'Are you trying to eliminate the static in your Radios if so send me your
address and I will send you the information on how a member did it on a
PT-26 with a a Ranger. send your address to fchld@rconnect.com.
John Berendt Fairchild Club
'Sure would like a copy John.
thanks,
Cliff McCluney
300 S. Goodman
Kerens, TX. 75144
thanks,
Cliff McCluney
300 S. Goodman
Kerens, TX. 75144
'John,
I am also interested in what a member did to resolve radio static on his
PT-26 with a Ranger. Please send this information to ME too.
1939 Fairchild 24 K
Stillwater, MN
1939 Fairchild 24 K
Stillwater, MN
Sent: Saturday, December 20, 2003 9:17 AM
> From: "fredakumpf"
'The Tulsa wing of the CAF is rebuilding a PT-19. The time has come to wire the mag
switches. Having no knowledge of RFI but knowing that the devil is always in the details I
asked this question of several people. As many said one end only as said both ends so I
thought I'd try here.
With more research I think I have ansewered my own question. The EAA publication
Firewall Foward by Tony Bingelis says on page 189 that you ground both ends which is what I propose to do. On page 190 it says to ground both ends of the shielding of all shielded wires.
If anyone else knows of a plabe where this is written down please let me know. We are
not yet trying to eleminate RFI, just avoid it if we can.
Thank you
1939 Fairchild 24 K
Stillwater, MN
Thank you
1939 Fairchild 24 K
Stillwater, MN
> From: "fredakumpf"
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
'My fix on my Ranger was pretty simple. I had a bad mag capacitor. Listened
to the radio on the right mag - OK, listened to it on the left - lots of
noise. Remove and replace fixed it.
Bob Webster
Bob Webster
Sent: Saturday, December 20, 2003 5:57 PM
> John,
> Thanks
> Bob Waldron
> 1939 Fairchild 24 K
> Stillwater, MN
> From: "John Berendt"
> > From: "fredakumpf"
> > To:
> > Yahoo! Groups Links
'Probably that was written when they didn't have a radio. Now days the recommendation is to ground only one end so you don't create radio noises.
Sent: Sunday, December 21, 2003 11:53 AM
Thank you
1939 Fairchild 24 K
Stillwater, MN
> From: "fredakumpf"
Do you Yahoo!?
Yahoo! Groups Sponsor
ADVERTISEMENT
