Re: SC 8.00 Tire
Bob & Ileen Waldron
SC 8.00 Tire
Post by Bob & Ileen Waldron »
'Fairchild Club people,
A few of you have Fairchilds that have an SC 8.00 Tailwheel tire. For those of you that need one, Bill Hughes has found a wonderful answer to your needs. Here is what Bill says:
Hi Bob.
I have spent many hours on the net locating this tire. It is an oval ribbed tire with almost exactly the same size and contour as the 8 SC we use and that is so hard to find. The tire is a 4 ply tube type tire. The tube has an angle valve stem. The tire and tube size is 2.50 x 3 and has a loading capacity is 220 lbs at 50 psi. I am currently running one with no problem. The tube is EXACTLY the same tube Dresser sells. I know because I have one of Dressers tubes. The tire may be the same but Dresser removes the manufactures name.
The cost is $10.15 for tire and $3.45 for tube plus $5.50 for shipping for total amount $19.10 for one set. .
You can order using your credit card and they will need your credit card information to process the order.
You can email your order to HChang@kendausa.com
Credit Card Number: _________________________________________
Exp. Date: ____/____/____
Type of card (circle one): Visa MasterCard Discover American Express
Name as it appears on credit card: ___________________________________________
Billing Street Address: ___________________________________________
Billing Zip: __________
You can also call (614) 866-9803 ext. 219 to place order
Snail Mail:
Hank Chang,
Kenda
7095 American PKWY
Reynoldsburg OH 43068
Info provided by:
Bill Hughes
6129 Circleview
Ft. Worth, Texas 76180
PT 22 N53146
Airy-Hugues Millet
Re: SC 8.00 Tire
Post by Airy-Hugues Millet »
'It is a very nice thing to know....but do you know if it could be the same
for 10inch (SC10) tires???
The 10 inches sold by desser is manufactured by STOMIL (a polish company
from the michelin group!)
but it cost really a lot ( around 110dollars only for the tire)...
so let me know if you have some tips about such old tires!!!
(SC10 is also called aero-standard no26 I guess)
Airy -H.MILLET
>From: "Bob & Ileen Waldron"
>To:
>CC: "john berendt"
>Subject: [fairchildclub] SC 8.00 Tire
>Date: Mon, 2 Jun 2003 22:10:32 -0500
>Hi Bob.
>manufactures name.
>Snail Mail:
>Hank Chang,
>Kenda
>7095 American PKWY
>Info provided by:
>Bill Hughes
>6129 Circleview
>PT 22 N53146
Hotmail : un compte GRATUIT qui vous suit partout et tout le temps !
http://g.msn.fr/FR1000/9493'
b guest
Re: SC 8.00 Tire
Post by b guest »
'Hi Bob,
Thanks for the info re S.C.8.00 Tires. Buyer be ware, if these are the same tail wheel tires we have experienced, be very sure that they fit perfectly to the 3" hub and that the pressure in the tube is correct or you will experience slippage and this will wipe off the stem and you'll be right back where you began. Not the first time this has occured so be careful.
> Hi Bob.
> Snail Mail:
> Hank Chang,
> Kenda
> 7095 American PKWY
> Info provided by:
> Bill Hughes
> 6129 Circleview
> PT 22 N53146
