Re: Prop Position
Prop Position
'With My Warner at TDC #1 What position should the prop be mounted?'
Re: Prop Position
'Tom, On my F-24W the prop is completely in the vertical position which makes doing the compression check kind of hard so I made up a special Milton fitting ( 90 degree) to attach to the compression plug to attach the air hose to.
"Tom Downey " wrote:With My Warner at TDC #1 What position should the prop be mounted?
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, and more
Do you Yahoo!?
