'I am looking for a set of mounting brackets to mount a bump cowling on a
Fairchild 24 with l45 hp Warner engine. Thanks
Sharon
Re: Cowling Mounting brackets
Tom Downey
'--- In fairchildclub@yahoogroups.com, SHEFLY@a... wrote:
cowl, like mine, I have an extra set.
Tom Downey
http://www2.whidbey.net/nc19143/index.htm'
on a> I am looking for a set of mounting brackets to mount a bump cowling
If the Brackets that you are looking for are the same as the smooth> Fairchild 24 with l45 hp Warner engine. Thanks
> Sharon
Tom Downey
Gene Lehman
'Sharon,
Bump cowling do not have mounting brackets. They only have cylinder stops for the rocker boxes so the cowling can not go forward into the prop. The cowling just rides the rockers.
Hope this helps,
Gene
Hope this helps,
Gene
