Re: Does anyone know where I can get pictures or prints
tkp0012002
'for a 1935 f 24 instrument panel? I am involved in restoration
project. We want to return the plane to original but the panel is
pretty well boogered up. We dont know where some of the indicators
really go. We are also trying to find aileron rod end bearings that
are .685 outer diameter .250 shaft size and .5 inch inner race width
but no luck so far. Thank you for any info you can provide. Tom Prose
Minnesota email tkp001@frontiernet.net'
'Tom, We are nearing the completion of our 1936 F24 C8E actually the 2nd
production ship and maybe, just maybe, these are the same. It was necessary
for us to also make a new panel although we had the old one as a template.
Should they be the same we can send photos and dimentions. I might even have
a advertisement of the instrument panel showing the layout. If you can give
me the model number of yours we can determine if they were the same or I can
send you earlier ads for your model. Give me you mailing address and I will
try to help.
try to help.
'> for a 1935 f 24 instrument panel? I am involved in restoration
jstreat360@aol.com
'B.guest,
When you dig up the 1936 F-24 ads, send me a copy so I can put that in the
Fairchild CD ROM volume set. Still working on gathering data for the club.
Visit my F-24 Web Site:
Visit my Light Aircraft Site:
Meet my Family:
Meet my Family:
'This one is a 1935 f 24 c8c sn 2671 145 hp warner. My full mailing address is
tom prose
8094 257th st w
Farmington, Mn. 55024
The oil press and oil temp are high in the middle area with a small oblong window right below for a light. There is no hump on top of panel as the later models had. Thank you so much. If you can send copies of whatever you have I will be more then happy to cover any costs involved. In case you need to call me 952 469 2493 . thank you again. tom
tom prose
8094 257th st w
Sent: Saturday, November 16, 2002 1:17 AM
Subject: Re: [fairchildclub] Does anyone know where I can get pictures or prints
try to help.
'I wanted to also pass along we had enough panel left around the outside to get the dimensions for it. I guess I didnt want to put you out by having to get all the dimensions for the indicators. If there is a mechanical drawing I would gladly have a copy. I forgot to mention we have found aileron crossover tube bearings from unieair. once again thank you. tom Original Message -----
try to help.
try to help.
To unsubscribe from this group, send an email to:> for a 1935 f 24 instrument panel? I am involved in restoration
'Check out this e-bay auction. FAIRCHILD PT-26A PROJECT WITH 200HP RANGER
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1872712169
Re: PT-26A
'To Fairchild Club memebers
Should a fellow Fairchild Club member purchase the PT-26A advertised
on eBay I have the records of the Cornells that served in the RCAF
and will share what I have on 42-71007.
Please note: I am not connected to the seller and did not know of
the Cornell existance before this evening. Just shows what is still
hidden away.
Tony
hidden away.
Tony
RANGER
cliffmccluney@webtv.net
Re: PT-26A
'Tony would you have the FZ xxx, Mfg. number for 42 71007?
I would like to look up the FAA data on it and since there is no N
number available will need the Mfg. number to locate the records.
thanks,
Cliff McCluney
PT-26 FZ 337
Kerens, TX.'
thanks,
Cliff McCluney
PT-26 FZ 337
Kerens, TX.'
Airy-Hugues Millet
Re: PT-26A
'have a look at
http://home.att.net/~jbaugher/1942_4.html
Airy-H. millet...hopes this could help!!
MSN Messenger : discutez en direct avec vos amis !
http://www.msn.fr/msger/default.asp'
_________________________________________________________________>From: cliffmccluney@webtv.net
>Subject: Re: [fairchildclub] Re: PT-26A
>Date: Wed, 20 Nov 2002 09:06:02 -0600 (CST)
>thanks,
>Cliff McCluney
>PT-26 FZ 337
>Kerens, TX.
'to: b guest in the fairchild club. Could you email me directly at tkp001@frontiernet.net about the instrument panel for the f24 c8c. thanks tom
try to help.
