'Could anyone tell me how many square yards of fabric/leather are required to upholster the two front seats + backs, the bench rearseat + back, the arm rests and the two door panels.
The service manual says 11 yds of 54" wide.This, I presume incudes the side walls as well for which I intend to use something different.
Thanks for your help
Re: Upholstery
Upholstery
'Be careful what you use. Our FSDO has just brought on a fellow who is doing a lot of nosing around here for approved materials in local aircraft. Basically, if you don't have the appropriately rated materials you may be heading down a troubled path with the Feds! Just a word of caution!'
Re: Upholstery
'Check your regs. "Approved" materials are not required for most part 91 iarcraft.
For what it is worth.
Re: Upholstery
'Well, they've always said the Northeast region is one of the toughest!'
Re: Upholstery
'You will need to have the material flame tested to meet the faa
requirement... walt
requirement... walt
Sent: Friday, May 17, 2002 9:32 AM
Subject: [fairchildclub] Upholstery
