'Well guys, I still have a bit of a problem with "dem brakes". I've replaced the fluid with the Dot 5 as per the Fairchild article. Followed the instructions to the letter, there's not one bubble in the system. Then, I put 5 lbs. pressure in the reservoir and bled them from the top, just a little at a time before adding more dot 5 and repressurizizing. The brakes work just fine after I pump them up a few times, but need to be re-pumped up after about 2 or 3 minutes.
Herby Carper (Master PT-19 restorer of 15 years on the same airplane) thinks the brake blocks may be worn down to the point that it takes extra pumping to get enough fluid in the expander tubes to activate the brakes, then when it's not being used the springs in the blocks allow the fluid back up the tubes. I haven't had the wheels off, so I don't know the condiditon of the blocks. Is that the logical next step? Also, there's no leaking of fluid anywhere I can see, the master cylinders show no indication of it either.
The good thing is that at least I have brakes (after pumping a few times), which is far better that what I had before..
Robert Hensarling
rhrocker@hilconet.com
www.mesquiterocker.com
Uvalde, Texas
Re: dem brakes
Marge & John Berendt
Re: dem brakes
'Bob
There shoud be only about .020 clearance between the blocks and the brake
drum. You can check this by looking through the little slots on the backing
plate. Use a feeler gauge to check them. Check this with the rakes relaxed
and then with the brakes being punped up.
Sent: Monday, January 14, 2002 7:39 AM
Subject: [fairchildclub] dem brakes
either.
> Robert Hensarling
> Uvalde, Texas
Re: dem brakes
'--- robert hensarling wrote:
Robert,
You won't see any leakage at all on the exterior. The
leaking is in the master cylinders themselves. Drain
the fluid, remove the cylinders and replace the seals
with the NAPA seal kits. This is the fix, there is
nothing wrong with the brake blocks.
Do You Yahoo!?
Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/'
Robert,
Do You Yahoo!?
robert hensarling
Re: dem brakes
Sent: Monday, January 14, 2002 4:06 PM
Subject: Re: [fairchildclub] dem brakes
Thanks Mike, I was dreading tearing into the brake blocks. I think I recall
that someone posted the NAPA specs for the seals a couple of weeks ago, but
I failed to file that info away. Anyone remember what the NAPA part number
is?
Robert Hensarling
> Robert,
> Mike
> Do You Yahoo!?
Pilot4906@aol.com
Re: dem brakes
'NAPA 190 master brake repair kit I think....
WALTER ALBERT
Re: dem brakes
'THE gap between the brake blocks and the brake drum should be between 7 and
ten thousands. this can be measured by flipping the tabs on the brake
assembly. walt
assembly. walt
Sent: Monday, January 14, 2002 8:39 AM
either.
> Robert Hensarling
> Uvalde, Texas
