Re: gemme a brake part two/expander tube mat'l
Tom_Downey
Post by Tom_Downey »
> Skydrol 5606 is even worse for damage in the brake system parts.
Jamie,
5606 is a red mineral based hydraulic fluid use extensively thruout
the General aviation industry. It comes in a blue or red can. Skydrol
is peroxide ester based fluid, and comes in 3 colors, green (Skydrol
3000), purple (Skydrol 500B), and clear (skydrol 1000).
I have never seen any Skydrol in use in GA aircraft under 12,500
Lbs. it's claim to fame is ability to operate in great temp.
extremes, and not burn, so think big jet.
All one must do to change to 5606 A or B is to disassemble, clean,
and reassemble using common AN/MS/NAS/AS "O" rings. It is a very
benign fluid which will not harm paint, or your skin.
Tom Downey A&P-IA
Aviation Hydraulic tech, USN retired'
WALTER ALBERT
Post by WALTER ALBERT »
'THERE IS ANOTHER GOOD SEALANT. LOCTITE 542 THREAD SEALANT OR HYDRAULICS
ETC... I USE IT ON ANYTHING ASSOCIATED WITH DOT 5. WALT
Sent: Sunday, December 23, 2001 8:34 AM
Subject: Re: [fairchildclub] gemme a brake part two
> Bob
> Dot 3 is a very good paint remover. And it is a bit on the corrosive
side.
> I use a sealer called "Tite Seal" I get it from Chief Aircaft Supply in
> Grants Pass Oregon their phone is 800-447-3408. titeseal come in two
> weights I use the medium weight Dot 5 will find every leak you have in
the
> system. I have one small leak but the amount does not bother. Also it
does
> not take off paint.
> John Berendt.
> From: "robert hensarling"
> Sent: Sunday, December 23, 2001 2:03 AM
> > From:
> > To:
> > Sent: Sunday, December 23, 2001 12:22 AM
> > Ok, I can do that. Is the Dot 3 corrosive? Do you have a suggestion
for
> a
> > sealant for fittings Jamie when using Dot 5?
> > Thanks!
> > Robert
> > > WARNING WARNING WARNING,
> > > NO DOT THREE BRAKE FLUID, DOT 4 OR SWITCH TO DOT 5.
> > > Jamie S. Treat A&P/IA
> > > Visit my Web Site:
HREF="http://hometown.aol.com/ftreat9191/AIRCRAFTRESTORATIONREPAIRindex.html
> > ">Aircraft Restoration & Repair
> > > Meet my Family:
> > > > HREF="http://hometown.aol.com/ftreat9191/TreatFamilyHomePage.html">Treat
> > Family Home Page
> > > [Non-text portions of this message have been removed]
> > > To unsubscribe from this group, send an email to:
> > > fairchildclub-unsubscribe@yahoogroups.com
> > > Your use of Yahoo! Groups is subject to
jstreat360@aol.com
Post by jstreat360@aol.com »
Left out the comma, We used Skydrol in out F-4, F-15 and F-16s in the
Airforce. True you can use it in most applications, but when it comes to the
old Expander type rubber, it will turn it soft and swell. End up with locked
brakes.
Visit my Web Site:
Meet my Family:
Tom_Downey
> Tom,
the
comes to the
with locked
> brakes.
are you saying the 5606 will soften the rubber? or the Skydrol? they
are 2 way different fluids.'
jstreat360@aol.com
I'm sure about 5606, I would say that would be true for Skydrol. Thetas what
happened to my bladder brakes on my F-24 before I purchased it. The previous
owner ended up replacing both bladders. The local Spam can mechanics filled
the brake system up with 5606, not knowing any better. I ended up rebuilding
the Master Cyl when I get it back to my shop. The piston seals were swelled
up and soft. They also painted all the brake parts with a two part paint.
Talk about a mess. The DOT 4 soften the paint, became like glue and hung up a
brake. Ended up with a locked right brake, blown tire and almost a fire.
Visit my Web Site:
Meet my Family:
Tom_Downey
> Tom,
Thetas what
previous
mechanics filled
rebuilding
swelled
paint.
hung up a
fire.
I know the Skydrol will destroy any system that was not designed for
it. It requires special seals and packings, made for the Peroxide
Ester base.
The tubes in your brake system must be natural rubber,because 5606
will desolve natural rubber, 5606 requires neoprene(SP) AN/MS "O"
rings.'
jstreat360@aol.com
'They are natural rubber.
Visit my Web Site:
Meet my Family:
Tom_Downey
Any of the old vegetable based fluids will work too, back in the 20's-
40's they had a fluid that was basicly "castor oil". But it would
freeze, mix with water and corrode the systems components. Yucky
stuff.
How many aircraft are running the expander tube type brakes? are
there any after market tubes? Where are you getting the seals for the
master cylinders? NAPA? is there a auto master cylinder that
Fairchild used?
I got more questions than I have answers at this point.
Tom Downey, spam can mech.
Cy Galley
Post by Cy Galley »
'So what should one use?
I had to drag a Fairchild off the runway at Oshkosh with a melted bladder.
Sent: Monday, December 24, 2001 9:40 AM
Subject: Re: [fairchildclub] Re: gemme a brake part two
Visit my Web Site:
Meet my Family:
Family Home Page
jstreat360@aol.com
Still quite a few of the Fairchilds running around with Expander (Hayes) type
brakes. I like them once you set them up right. As for tubes, new old stock
out of Fresno Airparts along with the Brake Blocks. Stock will someday run
out. Reason #1 to take care of the system with the correct fluid. Joe Denest
hates the Cleveland install on the PTs. Can't blame him, socks on a rooster
comes to mind. Hard to cover up Clevelands on a PT, just not that war time
look.
As for modern brakes. We have many FAA 337s for one time field approval to
convert to Clevelands. You can use the Cessna 310, three puck system, remove
the center pad for less brake. Or you can order the Cessna Ag Truck two puck
system. Also I have been looking at the NuWaco brakes that Cleveland designed
for the UPF-7. They will work on the Fairchilds if you remove the taper shaft
and install the straight axle. Waco has a problem selling the axle to none
Waco users. Still working the issue. I have all the engineering drawings on
file.
As for Master Piston seals, NAPA or any good Auto Parts house. May require a
special order, 1932 Plymouth Brake masters. The seals and springs will work,
will require use of your old Piston, unless you want to cut the new one in
half and then reweld (too long). This has been covered many times in the
Flyer Tech Tips. Go to Yahoo and look at the Tech Tips Index. In the process
of scanning in all the Flyers and will have index that is hyper text linked
to each issue, coming in the next CD Rom effort. Otherwise order paper copy
from John.
A few members have switched out there Auto style and gone to Bodell Masters,
We have the P/Ns for that also. Requires minor bracket rework.
Visit my Web Site:
Meet my Family:
