UC61K Forwarder
almorris@mweb.co.za
UC61K Forwarder
Post by almorris@mweb.co.za »
'In reply to the query about F24 being exported, my F24 U.S. Army serial No. was 44-83221 which became KK521 under the R.A.F. On a visit to the U.K. I went to the R.A.F. museum at Hendon. They have a special enquiry counter and I wrote a quick note asking about the history of my aircraft. I received a reply about a month later with a form stating the date the aircraft arrived in North West Africa and the date the aircraft was struck off charge. This aircraft was flown to South Africa from North Africa and I believe more than 50 F24's were registered in South Africa in the late 40's. Tracy Robb has most of the details of F24's registered in this country. An airline was started here in the late 40's flying between Johannesburg and Durban, a 4 hour flight. Take off early in the morning and the same aircraft would do the return flight late afternoon. The adress of the R.A.F. Museum is -Graham Park Way, Hendon, London,NW9 5LL. U.K.
Any one know of where I can get a replacement valve for a fuel cock?
Great bulletin board.
Martin Morris
lov2fly28525@cs.com
Re: UC61K Forwarder
Post by lov2fly28525@cs.com »
'It your fuel valve is just leaking, they can be repacked. Go to your local
plumbing store, they have teflon packing that works great.
AL Rice
NC28525
Meridian, Idaho
almorris@mweb.co.za
UC61K Forwarder
'Tony, you were right about the U.S.Army serial Number. I misread the S.A. register. The only info. I got from the R.A.F. was the date the F24 arrived in Africa which was Feb. 1945 and the letters FLCD Almega 27/8/46. As the F24 has been resprayed to the silver stage I need to make adecision on the final paint scheme so any info would be greatly appreciated.
Al Rice thanks for the info but my valve section was so corroded the brass has fused with the metal shaft and the spring has disappeared.
Thanks again all.
Martin
