'I believe Desser Tire has these for a price. www.desser.com. I put the
R-R-R-Russ Aircraft STC (www.russaircraft.com) on my tailwheel with no
regrets. Less expensive in the long run.
AL Rice
Meridian, Idaho
NC28525
Re: need inner tube
Re: need inner tube
'John,
No 90 degree stem, call Desser Tire. They have the tubes, not cheap $110.00
per copy and going up. They may have the short stem type in stock, see the
latest Fairchild Flyer issue, same subject. Also if you have a torn stem, get
a new one vulcanized on. Did mine two weeks ago, $5.00 repair with short stem.
Visit my Web Site:
Meet my Family
Visit my Web Site:
Meet my Family
Re: need inner tube
'John
Jamie Treat is right. Have a short stem vulcanized on. I did this on my PT
and I use a stem extension when I need to put air in the tire. Stole the
extensio of my wifes thunderbird.
Sent: Friday, October 05, 2001 9:36 PM
Subject: [fairchildclub] need inner tube
> Where can we get inner tube for 10:00SC tail wheel. (must have 90 bend on
> stem.
> Thanks
> John
Re: need inner tube
'Al,
How has the STC from Russ working out? When Russ first contacted me I
thought it was a good idea. It should also help with any shimmy in the tail
wheel.
wheel.
Sent: Friday, October 05, 2001 9:51 PM
Subject: Re: [fairchildclub] need inner tube
> AL Rice
> Meridian, Idaho
> NC28525
Re: need inner tube
'-----Original Message-----
From: Marge & John Berendt [mailto:mjbfchld@rconnect.com]
Sent: Saturday, October 06, 2001 7:49 AM
Al,
wheel.
Al,
wheel.
Hi Al, what is the R-R-R-Russ Aircraft STC? I'm into shimmy problems with
my 46 24 R .
Bob Haas Buckingham AAFB FL
> AL Rice
> Meridian, Idaho
> NC28525
Re: need inner tube
'My airplane (almost) has no shimmy. The STC installs a standard 10/4 tire.
I believe that more tread surface on the ground reduces the chance of a
shimmy and helps steering when you need it the most.
Al Rice
Meridian, Idaho
NC28525
Al Rice
Meridian, Idaho
NC28525
Re: need inner tube
'desser tires has the tube with the 90 degree bend. I am
using it on my 24.
using it on my 24.
'> John
> John Berendt
> From: "John Ellis"
> > stem.
> > Thanks
> > John
Re: need inner tube
'With the inner tube I got from Desser I was always able to push the
stem over get the cover plate in place.
However, the Russ conversion is a great way to go and the stem is even
shorter. Required the extension(not stolen from my wife's T-bird) to
fill though. When pointed straight out it was mostly within the wheel
cavity.
Nice to be able to get tubes and tires at any supply place. Does
appear to help a bit with the shimmy too.
cavity.
90 bend on> > From: "John Ellis"
> > To:
http://docs.yahoo.com/info/terms/> > > stem.
> > > Thanks
> > > John
> > > fairchildclub-unsubscribe@y...
