'HI
Does anyone out there know were I might be able to find a tail wheel
assy upper attach bolt for a PT-19? It's a AN5-77. I have look all
over for the bolt with no luck.
Thane Riffle'
Re: PT-19 tail wheel attatch bolt
bt13a@earthlink.net
'Thane....I'll double check and make sure I don't have one still laying
around. You might call Spencers'....I seem to recall I ordered one
from them when I was rebuilding the tailwheel assy.
'--- In fairchildclub@y..., thane@m... wrote:
> HI
> Thanks
> Thane Riffle
bt13a@earthlink.net
'Hey....I just checked Wicks Aircraft on line(wicksaircraft.com),
1-800-221-9425, and they show one in stock. It's an
AN5-77A(undrilled).
Curt
AN5-77A(undrilled).
Curt
laying
> Curt Kinchen
> > HI
wheel
> > Thanks
> > Thane Riffle
thane@mindspring.com
'Thanks Curt
I did check Spencers, no luck the last time thay had one was in 1994.
Thats the one you got I bet :-}
I'll get it from Wicks. Thanks for the heads up. If you get a chance
stop by Crest and check out the PT.
Thane
Thane
> AN5-77A(undrilled).
> Curt
> laying
one
> > Curt Kinchen
> > > HI
> wheel
all
> > > Thanks
> > > Thane Riffle
