I've been trying to keep my recently purchased 1937 G-24 in shape. The tailwheel is free pivoting with coil spring and oil strut. My operator's manual describes removing a plug on the side of the strut tube and filling the strut with oil from a top plug until oil flows the side plug hole. Well, I don't have a side plug. There is a hole in about the right location, but no plug, and the hole is not even threaded. I went ahead and filled the strut until oil ran out of the hole and left it at that, but should I have an uncovered hole there? Also, exactly what type of oil should one use for the struts? I used hydraulic jack oil this time around. Finally, the plane came with a Scott wheel and tire, which shimmies. John Berendt passed on the following advice:
'I actually have two of the original 8" streamline tailwheels; does anyone know if there is a tire in production that can be mounted on them?Dan, The shimmy can be fixed. First contact Russ Harmuth at RRR-us Aircraft. He has a STC to put a
square shoulder tire on the Fairchild tail wheel. His phone is (209) 795-1817. He has a 800 number also. If you find a copy of the General Aviation News Russ advertises in there. A longer drag link will help also. Bill Spriggs in California had some made; you have to machine
it out. Bills phone number is (805) 644-5503.
Thanks, Dan Casali
-- Dan Casali, Publisher
Lost River Press
Box 1286 Ketchum, ID 83340
208.726.5120
