PT 26 wing bolts
Posted: Fri Jan 05, 2024 1:34 am
by awilson001@sympatico.ca
Hello,New to the forum first post, we are the Canadian Aviation Museum in Windsor Ontario Canada and are the process of reassembling our Fairchild PT26 Cornell. We are in need of one forward wing bolt part # 63136 and one aft wing bolt part # 63137 or the spec’s to manufacture these bolts. Thanks Al
Re: PT 26 wing bolts
Posted: Tue Jan 09, 2024 5:54 pm
by cvairwerks
Check with Mike and see if he has the bolt drawings. I know the Air Corps Library does not have them. In the meantime, I'll look thru the AT-21 drawings for the bolts for it. Same design, but different sizes, so the material callouts, threading information and heat treat should be the same.
Craig
AT-21
42-48053
Posted: Tue Jan 09, 2024 8:18 pm
Thanks much for the reply Mike. Al
Posted: Tue Jan 09, 2024 8:20 pm
Sorry Craig for the miss name, thanks for the reply how do I connect with Mike. Thanks Al
Posted: Wed Jan 10, 2024 4:00 pm
by cvairwerks
Is no sweat, not bothered at all... Mike is Mike Kelly and he runs the club. Here's his online contact info:
Mike Kelly
hotfoot149@gmail.com
Posted: Tue Jan 30, 2024 6:54 pm
Thanks Craig. Al
