warner pistons
Posted: Wed Mar 06, 2019 9:57 am
by paul pinato
'Hi
I am doing a top overhaul on my warner 165.
Lifting the #7 cylinder I found the piston to be
cracked.
The crack goes from the bottom skirt-through the
lower oil ring grove and up halfway to the third
piston ring.
The crack is located in the middle between the
piston pin holes.
Is there somebody that have seen this before.
As it is piston #7 I can not blame a hydraulic
lock.
I am also looking for 3/8 cylinder hold down studs
and it´s nuts. The crankcase has the 5/16 studs
but all my cylinders have 3/8 holes.
Paul
UC61A 314840
SE-AWS
Buy AeroShell here
https://webshop.eas.se
Nu även med:
Swish
Paul Pinato
Östergatan 184
26 151 Landskrona
Sweden
+46 (0)705 411 118
paul.pinato@telia.com
Re: warner pistons
Posted: Thu Mar 07, 2019 11:12 am
by John Duncan
' #ygrps-yiv-443450548 P {margin-top:0;margin-bottom:0;} Hello Paul,
I am sorry to hear about your broken piston.  I have no reports of a similar problem.
I have the 3/8 cylinder holddown studs in stock, and I may have the associated nuts.  (They are in short supply).  I will check inventory.  When you determine ALL the parts that you need, fill out a Part request form from the website and email it to me.
Thanks for the email, and I am sorry to hear of your problems.  Please let me know if you find anything else unusual with the engine.
Kindest regards,
John Duncan
Warner Engines llc
From: fairchildclub@yahoogroups.com on behalf of 'Paul Pinato' paul.pinato@telia.com [fairchildclub]
Sent: Tuesday, March 5, 2019 10:21 AM
Subject: [fairchildclub] warner pistons
Hi
cracked.
piston ring.
piston pin holes.
lock.
Paul
UC61A 314840
SE-AWS
Buy AeroShell here
Nu även med:
Swish
Paul Pinato
Östergatan 184
26 151 Landskrona
Sweden
+46 (0)705 411 118
Re: warner pistons
Posted: Fri Mar 08, 2019 2:52 pm
by Jp Lorie
'Harman Dickerson should have what you need (573) 449-6428 I also found a cracked cylinder in the same way when I did my overhaul.
J.P. Lorie`
On Mar 7, 2019, at 12:12, John Duncan johnaduncan@msn.com [fairchildclub] wrote:
Hello Paul,
Kindest regards,
John Duncan
Warner Engines llc
Hi
cracked.
piston ring.
piston pin holes.
lock.
Paul
UC61A 314840
SE-AWS
Buy AeroShell here
Nu även med:
Swish
Paul Pinato
Östergatan 184
26 151 Landskrona
Sweden
+46 (0)705 411 118
Re: warner pistons
Posted: Sun Mar 10, 2019 3:24 pm
by Jp Lorie
'Having only briefly scanned your email, I did not see that John Duncan had already replied. He is also a very good and reputable source for Warner parts.  I have done business with him as well.It was an oversight on my part to not have mentioned him.
J.P. Lorie`
J.P. Lorie`
Hello Paul,
Kindest regards,
John Duncan
Warner Engines llc
Hi
cracked.
piston ring.
piston pin holes.
lock.
Paul
UC61A 314840
SE-AWS
Buy AeroShell here
Nu även med:
Swish
Paul Pinato
Östergatan 184
26 151 Landskrona
Sweden
+46 (0)705 411 118
