Prop nut spec
Posted: Wed Jun 01, 2016 10:07 pm
by Ranchaero Wing Shop
' Curt, do you know where could I find the AN5011-20 nut spec?
I measured the cone and spacer which both measure slightly less than 1" (.957 and .995).
Next I need to compare my nut with the spec.
David
On 5/29/2016 7:26 AM, Curt kinchen ptcurt@gmail.com [fairchildclub] wrote:
Take it back, it was the nut spec I posted. AN5011.
Sent from my iPad
> On May 29, 2016, at 7:13 AM, Curt kinchen
class="moz-txt-link-rfc2396E" href="mailto:ptcurt@gmail.com">ptcurt@gmail.com wrote:
> I've seen some cones that had "built in" spacers, with a
significant amount of straight section before the taper.
> AN5008-20 cone and AN5010-20 spacer. The non tapered section
Dimension E is shown as .438 in the spec, but I recall seeing some with not that much straight. The link below is for the cone. The spacer spec isn't showing up, but I believe I posted the spec to the files folder at one time.
href="http://everyspec.com/MS-Specs/MS5/downl ... 018742.PDF
Re: Prop nut spec
Posted: Thu Jun 02, 2016 8:43 am
by Hugh Loewenhardt
'All,
  The detail drawing for the AN5011 hub nut is in the Fairchild Group files. It posted in 2011. Go the group and click on File on top of page.
On Thursday, June 2, 2016 12:07 AM, "Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]" wrote:
David
On 5/29/2016 7:26 AM, Curt kinchen ptcurt@gmail.comptcurt@gmail.com [fairchildclub] wrote:
Sent from my iPad
> On May 29, 2016, at 7:13 AM, Curt kinchen ptcurt@gmail.comptcurt@gmail.com
#ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621 -- #ygrps-yiv-1781441357yiv4702838621ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp #ygrps-yiv-1781441357yiv4702838621hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp #ygrps-yiv-1781441357yiv4702838621ads { margin-bottom:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad { padding:0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad p { margin:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc { font-family:Arial;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc #ygrps-yiv-1781441357yiv4702838621hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc .ygrps-yiv-1781441357yiv4702838621ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span { font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span span { color:#ff7900;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span .ygrps-yiv-1781441357yiv4702838621underline { text-decoration:underline;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach div a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach img { border:none;padding-right:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach label a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621bold a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p span.ygrps-yiv-1781441357yiv4702838621yshortcuts { margin-right:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621attach-table div div a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621attach-table { width:400px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:active, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:hover, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:visited { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:active, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:hover, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:visited { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div#ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg #ygrps-yiv-1781441357yiv4702838621ygrp-msg p a span.ygrps-yiv-1781441357yiv4702838621yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621green { color:#628c2a;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 o { font-size:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div { float:left;width:72px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621reco-category { font-size:77%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621reco-desc { font-size:77%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621replbq { margin:4px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg select, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 input, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg pre, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 code { font:115% monospace;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg #ygrps-yiv-1781441357yiv4702838621logo { padding-bottom:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-msg p#ygrps-yiv-1781441357yiv4702838621attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-reco #ygrps-yiv-1781441357yiv4702838621reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text { font-family:Georgia;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text tt { font-size:120%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1781441357
Re: Prop nut spec
Posted: Thu Jun 02, 2016 8:49 am
by Curt Kinchen
'I happen to have it right here.  I'll send it via email to you directly.  I'll try to remember to post it to the files section of the group site when I get a chance.
On Wed, Jun 1, 2016 at 9:06 PM, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
David
Sent from my iPad
> On May 29, 2016, at 7:13 AM, Curt kinchen ptcurt@gmail.comptcurt@gmail.com wrote:
> I've seen some cones that had "built in" spacers, with a significant amount of straight section before the taper.
> AN5008-20 cone and AN5010-20 spacer. The non tapered section Dimension E is shown as .438 in the spec, but I recall seeing some with not that much straight. The link below is for the cone. The spacer spec isn't showing up, but I believe I posted the spec to the files folder at one time.
> http://everyspec.com/MS-Specs/MS5/download.php?spec=MS5008D.018742.PDF
ptcurt@gmail.com '
