'The primer is located on the engine mount left side next to the spot where the hand crank starter is inserted. The guy who gets to crank the "armstrong" starter injects a couple shots of prime before cranking the engine.
Mike Denest
"He's crazy Lew, he builds toy airplanes!"
- Frank Towns Flight of the Phoenix
On Friday, February 5, 2016 7:56 PM, "Ranchaero Wing Shop
david@ranchaerowingshop.com [fairchildclub]" wrote:
John, one other question maybe you can help me with. There is no obvious place on the panel or on the left side of the cockpit to mount the primer. Where was it mounted? There's a PT-26 here at Ranchaero, and it's primer is mounted on a small side panel on the left side of the cockpit. Is this what was done on the -19? If so I'm going to have to find or make such a panel.
Thanks for your help,
David
On 2/3/2016 5:57 AM, 'John Ellis'
johnee35@att.net [fairchildclub] wrote:
Originates at fuel strainer, to primer, to carburetor hot spot..
Pressure connection is correct..
John
Sent: Tuesday, February 2, 2016 8:28 PM
fairchildclub@yahoogroups.com
Subject: [fairchildclub] Stromberg carb connections
Dear list,
I'd appreciate if someone could verify for me the fuel pressure and
primer connections to the Stromberg carb. I assume the fitting just
above the fuel inlet is the fuel pressure connection, and the float bowl
drain is where the primer hooks up. Correct?
David
Posted by: Ranchaero Wing Shop
Yahoo Groups Links
This email has been sent from a virus-free computer protected by Avast.
www.avast.com #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772 -- #ygrps-yiv-1012798498yiv5458772772ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp #ygrps-yiv-1012798498yiv5458772772hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp #ygrps-yiv-1012798498yiv5458772772ads { margin-bottom:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad { padding:0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad p { margin:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc { font-family:Arial;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc #ygrps-yiv-1012798498yiv5458772772hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc .ygrps-yiv-1012798498yiv5458772772ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span { font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span span { color:#ff7900;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span .ygrps-yiv-1012798498yiv5458772772underline { text-decoration:underline;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach div a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach img { border:none;padding-right:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach label a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772bold a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p span.ygrps-yiv-1012798498yiv5458772772yshortcuts { margin-right:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772attach-table div div a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772attach-table { width:400px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:active, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:hover, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:visited { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:active, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:hover, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:visited { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div#ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg #ygrps-yiv-1012798498yiv5458772772ygrp-msg p a span.ygrps-yiv-1012798498yiv5458772772yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772green { color:#628c2a;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 o { font-size:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div { float:left;width:72px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772reco-category { font-size:77%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772reco-desc { font-size:77%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772replbq { margin:4px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg select, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 input, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg pre, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 code { font:115% monospace;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg #ygrps-yiv-1012798498yiv5458772772logo { padding-bottom:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-msg p#ygrps-yiv-1012798498yiv5458772772attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-reco #ygrps-yiv-1012798498yiv5458772772reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text { font-family:Georgia;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text tt { font-size:120%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1012798498
