Cylinder Assembly for Continental Engine
Posted: Sun Aug 30, 2015 6:46 pm
' Hello Fairchild Lister... I got a lot of Ranger Engine parts from an old friends estate sale.. Included in this were two cylinders for a Continental Engine. The cylinder, piston, piston pin, piston rings, valves, and rocker cover with gasket are assembled and wrapped in plastic.. The cylinder casting number is : MFC 6674 or 8874 piston is Superior # 530348 std Cylinder bore is 4 1/16 ( I think, used dial caliper through holes in plastic ) If you can use, please send email with an offer.. I haven’t worked on a Continental in last 25 years.. johnee35@att.net Have a fun Day... John'
