'To clarify the orginal instrument marking question: general aviation aircraft certified by Part 3 of the Civil Air Regulations (CARs) adopted in 1938 required instruments to be marked in accordance with Sections 3.756 thru 3.765 as mandated by Section 3.385. The requirement would have applied to the original civilian version of the Fairchild PT and civilianized military aircraft of that era. From 1926 to 1938, aircraft were certified in accordance with Aeronautical Bulletins. Civil Air Manuals (CAMs) were issued to provide guidance for compliance with the CARs. Federal Aviation Regulations issued by the FAA superseded the CARs of the Civil Aeronautics Administration (CAA).
On Thursday, July 2, 2015 9:29 PM, "'Cy Galley'
cgalley@mchsi.com [fairchildclub]" wrote:
Right but a Fairchild is a CAM certified plane that doesn't meet part 23 and never has to.
Sent: Thursday, July 02, 2015 4:16 PM
Subject: Re: [fairchildclub] Instrument range markings Federal Aviation Regulations (FARs) Part 23, Airworthiness, Markings and Placards Section specify the mandatory requirements for designated instruments and the marking of their minimum and maximum limits. The markings are usually required for airworthiness signoff on our category of aircraft but not always, depending on the A&I. Colored tape can be used for the marks and removed later should the markings be objectionable for some reason. On Thursday, July 2, 2015 1:04 PM, "Curt Kinchen
ptcurt@gmail.com [fairchildclub]" wrote: Believe the TCDS limits need to be readily available to the pilot(placard, range on instrument, etc.). On Wed, Jul 1, 2015 at 5:36 PM, Hans Friedebach
hans@tsoproducts.com [fairchildclub] wrote: AC 20-88A is an excellent description what markings should look like. I didn’t see anything about mandatory requirements. Type certificate data sheets any help?
Sent: Wednesday, July 01, 2015 5:57 PM
Subject: Re: [fairchildclub] Instrument range markings Advisory Circular AC 20-88A provides guidelines for marking minimum and maximum instrument limitations. The AC document, available online, references applicable Part 23 FARs also available online. On Monday, June 29, 2015 10:39 AM, "
cmueller@csuchico.edu%20[fairchildclub]" wrote: Are instrument range markings required on older aircraft?
That's an in-general question, but I'm thinking of a 1943 PT. I realize they are a smart thing to add, but is it a requirement? Charles
-- Curt Kinchen
ptcurt@gmail.com #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 -- #ygrps-yiv-1819890599yiv3552686194ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp #ygrps-yiv-1819890599yiv3552686194hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp #ygrps-yiv-1819890599yiv3552686194ads { margin-bottom:10px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp .ygrps-yiv-1819890599yiv3552686194ad { padding:0 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp .ygrps-yiv-1819890599yiv3552686194ad p { margin:0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mkp .ygrps-yiv-1819890599yiv3552686194ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ygrp-lc { font-family:Arial;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ygrp-lc #ygrps-yiv-1819890599yiv3552686194hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ygrp-lc .ygrps-yiv-1819890599yiv3552686194ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity span { font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity span span { color:#ff7900;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194activity span .ygrps-yiv-1819890599yiv3552686194underline { text-decoration:underline;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194attach div a { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194attach img { border:none;padding-right:5px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194attach label a { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194bold a { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 dd.ygrps-yiv-1819890599yiv3552686194last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 dd.ygrps-yiv-1819890599yiv3552686194last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 dd.ygrps-yiv-1819890599yiv3552686194last p span.ygrps-yiv-1819890599yiv3552686194yshortcuts { margin-right:0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194attach-table div div a { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194attach-table { width:400px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194file-title a, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194file-title a:active, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194file-title a:hover, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194file-title a:visited { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194photo-title a, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194photo-title a:active, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194photo-title a:hover, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div.ygrps-yiv-1819890599yiv3552686194photo-title a:visited { text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 div#ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg #ygrps-yiv-1819890599yiv3552686194ygrp-msg p a span.ygrps-yiv-1819890599yiv3552686194yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194green { color:#628c2a;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 o { font-size:0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194photos div { float:left;width:72px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194reco-category { font-size:77%;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194reco-desc { font-size:77%;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 .ygrps-yiv-1819890599yiv3552686194replbq { margin:4px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg select, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 input, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg pre, #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 code { font:115% monospace;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-mlmsg #ygrps-yiv-1819890599yiv3552686194logo { padding-bottom:10px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-msg p#ygrps-yiv-1819890599yiv3552686194attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-reco #ygrps-yiv-1819890599yiv3552686194reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-sponsor #ygrps-yiv-1819890599yiv3552686194ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-text { font-family:Georgia;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-text tt { font-size:120%;} #ygrps-yiv-1819890599 #ygrps-yiv-1819890599yiv3552686194 #ygrps-yiv-1819890599yiv3552686194ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1819890599
