UC61K throttle & mixture rod firewall seals
Posted: Mon Mar 23, 2015 3:26 pm
by coxargus
'What are those lucky people with UC61ks using for the seals for the throttle and mixture control rods where they pass through the firewall?
I am not keen on the small boot on the cockpit side of the firewall - not exactly fireproof.
I'm looking at joystick style rubber bellows but can't find anything that's anywhere near fireproof. Also flexible silica braided conduit which could be made to work.
Just interested to hear what other folk have done or intend to do.
Thanks all
Frank
Re: UC61K throttle & mixture rod firewall seals
Posted: Tue Mar 24, 2015 1:23 am
by Airy-H. Millet
' just apply this kind of protection to original designed leather boots (which can be reinforced with fiberglass boot on the engine side, just such as the fiber glass used in sandwich firewall material).
http://www.restom.net/moteur-pont-boite-de-vitesse-restom-anti-feu-9530-anti-feu-2-videos-514.htm
(sorry French website with French product, click on the video for example of use).
(you make direct request in English to this website for more explanations).
Airy
Date: Mon, 23 Mar 2015 14:26:38 -0700
Subject: [fairchildclub] UC61K throttle & mixture rod firewall seals
Thanks all
Frank
Posted: Tue Mar 24, 2015 6:05 am
by Joe Preston
' Haven’t investigated it thoroughly but these firewall fittings may be an option. They are for both experimental and certified   http://www.doubleteeproducts.com/story.html   Let us know what you decide.   Joe   From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Tuesday, March 24, 2015 3:23 AM
To: fairchildlist
Subject: RE: [fairchildclub] UC61K throttle & mixture rod firewall seals     just apply this kind of protection to original designed leather boots (which can be reinforced with fiberglass boot on the engine side, just such as the fiber glass used in sandwich firewall material).
Airy
Thanks all
Frank
Posted: Thu Mar 26, 2015 6:12 am
by FJC
'Thanks Airy,
Sounds good - I am working on it.
Frank
Sent: 24 March 2015 07:23
To: fairchildlist
use).
Airy
_____
exactly fireproof.
made to work.
Thanks all
Frank
Posted: Thu Mar 26, 2015 6:16 am
by FJC
'Thank you Joe,
This would be the perfect solution. However there is vertical movement of
the rods relative to the fire wall - hence my query.
It is an awkward one to get a good seal.
Frank
Sent: 24 March 2015 12:06
Haven't investigated it thoroughly but these firewall fittings may be an
Joe
To: fairchildlist
use).
Airy
_____
exactly fireproof.
made to work.
Thanks all
Frank
