Warner Motor mount outer shell diameter.
Posted: Sat Aug 16, 2014 9:01 am
				'Am I correct?  Is the outside diameter of the outer bushing shell for the rubber mounts 1.247"?  (Ref: dwg. #48568)  If that is true, darn.....they, the outer shells, are sure tough to get out. If the outer diameter is more like 1.100", then I am trying to remove the wrong pieces, and my outer shells have already been removed and I am SOL.  Short On Luck. I am making progress.  I have the tail group & ailerons up through the early coats of  silver.   I may have them all up through color and have made final assembly within 2-3 months. Bob'
