				Source for manuals.
				Posted: Tue Jun 03, 2014 2:07 pm
				by Michael Kelly
				'   Bill:  You might try ESSCO Aircraft. They do manuals of all kinds
www.esscoaircraft.com 877-318-1555 (toll free) 888-249-4165 (toll free fax)
Mike Kelly Fairchild Club
				Anti chafing material for oil tank (PT-19)
				Posted: Tue Jun 03, 2014 2:46 pm
				by Ranchaero Wing Shop
				'Hi,
 I'm looking for anti-chafing material to be used between the oil tank
 and firewall, and under the oil tank straps. I've seen felt used on the
 firewall, and cowling chafe cloth tape, but these tend to soak up oil.
 Any better ideas?
 David
 This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com'
				Re: Anti chafing material for oil tank (PT-19)
				Posted: Tue Jun 03, 2014 2:49 pm
				by Gene Haines
				'We used strips of FAA approved and certified rubber roofing.
david@ranchaerowingshop.com [fairchildclub]
 To: fairchildclub
 Sent: Tue, Jun 3, 2014 4:46 pm
 Subject: [fairchildclub] Anti chafing material for oil tank (PT-19)
                                                              Hi,
  Any better ideas?
  David
				Posted: Tue Jun 03, 2014 4:08 pm
				by Francisco Molina
Cork El 03/06/2014 13:50, "Gene Haines
 From: Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]
  To: fairchildclub
                                                              Hi,
  Any better ideas?
  David
				Posted: Tue Jun 03, 2014 4:15 pm
				by FJC
				'I used 'Viton Rubber' - I'm in UK - not sure who has it in the US. It's
 available in all thicknesses and widths or get a sheet and cut off strips as
 required.
 Googling 'Viton Rubbe'r  should find a supplier.
 Frank
 Sent: 03 June 2014 21:37
 Hi,
 Any better ideas?
 David
				Oil cooler duct
				Posted: Thu Jun 05, 2014 11:23 am
				'Thanks for everyone's input on the anti-chafing material. Rubber sounds
 good to me.
 Another question: I'm fitting up the oil system components, and can't
 get the oil cooler duct (the one exiting the cooler) to fit. It rubs
 against the oil tank. I see where it has chafed over the years. I'm
 tempted to modify the oil cooler brackets to allow me to move the oil
 cooler forward an inch or two, but that would require surgery - cut and
 weld, which I can do, but there must be something I'm overlooking. The
 cooler brackets don't allow much range of position. Any advice will be
 much appreciated!
 David
