Oily belly problem solved, I think
Posted: Mon Jan 30, 2012 6:10 pm
'Yesterday flew 0.5 hours, lost 0.5 gal 120W Aeroshell oil, most of it appeared to be on the belly of my PT-26.
End of breather tube had been left as originally cut with a squared off end that is 5 inch below the belly. Tube slopes aft at angle of the lower firewall.
This morning cut the tube end so the opening is parallel to the belly pan about 8" behind the firewall bottom, still 5" below the belly pan.
Took a short hop (0.3 hr) to see if that made a difference - and came back with a clean belly!
I'll put a photo of the tube in the album N69167.
What a relief.
Charles'
What a relief.
Charles'
