--- In
fairchildclub@yahoogroups.com, Michael Denest  wrote:
 > I believe Sgt. Schultz said it best.
http://www.youtube.com/watch?v=34ag4nkSh7Q
 > Mike Denest
 > ________________________________
 > From: Cy Galley
 > Sent: Friday, September 16, 2011 2:54 PM
 > Subject: RE: [fairchildclub] Re: PT-26 with 175 hp Ranger
 > You are an optimist!
 > From:
fairchildclub@yahoogroups.com] On Behalf Of Gene Haines
 > Sent: Friday, September 16, 2011 1:04 PM
 > Subject: Re: [fairchildclub] Re: PT-26 with 175 hp Ranger
 > There should be an entry in the engine log if the engine has non standard piston for the 175 HP Ranger..
 > -----Original Message-----
 > From: ccmueller001
 > To: fairchildclub
 > Sent: Fri, Sep 16, 2011 12:34 pm
 > Subject: [fairchildclub] Re: PT-26 with 175 hp Ranger
 > I just checked for a domed piston (with a carefully bent coat hanger through a spark plug hole) and found a domed piston. It appears to have about a 3/8" rise from side to center. Is this about right for a 200 hp (-5 Ranger) engine?
 > Perhaps I have a 6-440C-5 engine with a 6-440C-2 data plate?
 > Any suggestions on which way to go from here (to keep the faa happy and not asking my mechanic to stick his neck out)?
 > Charles
 > --- In
fairchildclub@yahoogroups.com  , Curt Kinchen  wrote:
 > > It's likely that your -2 engine isn't and really is a 200HP. The difference
 > > between 175 and 200 HP is the domed pistons bumping the compression ratio
 > > and the ignition timing(25BTC for the 200 vs 22 for the 175). If you have a
 > > Stromberg carb the settings are different.
 > > On Thu, Sep 15, 2011 at 1:02 PM, ccmueller001  wrote:
 > > > According to the STC for the PT-26 it should have a Ranger L-440-C-5 engine
 > > > (200 hp) installed. Looking things over closely I find I have the -2 (175
 > > > hp) engine installed. Phooey!
 > > > Two questions:
 > > > Is there a 337 out there for using the -2 engine? I would prefer the
 > > > additional 25 hp as I fly out of a 1700 ft strip with lots of orchards all
 > > > around, though the elevation is just 175 ft MSL. But avoiding engine work at
 > > > this time would be nice too.
 > > > And: what is involved in converting a -2 to a -5 engine? Is it just
 > > > pistons?
 > > > Any input will be appreciated.
 > > > Charles
 > > Curt Kinchen
 > > ptcurt@
