WarnerGaskets
Posted: Wed Aug 31, 2011 10:51 am
'Hello good people,
As my project is nearing completion I am going to replace the push-rod tube hoses, that is the 2" long hoses that connect the push-rod tube to the nipple on the engine. I am attempting to do this without removing the cylinders because the engine only has 115 hours since major overhaul. but the hoses are not young and healthy because, the overhaul was done 20+ years ago. Do any of you have experience doing this hose change? If so I am all ears! Please advise of the best and easiest way.
Will I need new exaust and intake tube gaskets is there a source of gaskets that will work on this engine?
JP.Lorie
Florida
JP.Lorie
Florida
