'Hi JP
 Just did this job on four of my cylinders. Once
 the clamps are lose you just turn the
 push-rod-tube. I cut my spanner to about eight ?
 ten inches long and had to grind it very tin so I
 could turn it and change grip. I tried with a ring
 spanner by open it so the tube just entered but
 some of the tubes where hard to loosen so the
 spanner opened up and slipped.
 It is a pain staking job. Finger knuckles will
 bleed. You need also to know a lot of nasty words
 as you will need them to.
 You can only turn the tube one twelfth of a turn
 at the time. The one on the intake side are
 difficult not saying  impossible. It is so that
 the intake manifold and push-rod tube on that side
 are installed before installing the cylinders .
 When turning the tube the hose will turn on the
 engine boss. So if the hose is stuck on the tube
 you will work against that to by compressing it.
 Do not cut the hose with a knife.
 If you remove the exhaust manifold it will be
 easier.
 Also the hexagon grip on the tube is very thin and
 the metal is soft. I damaged two of them and had
 to pull the cylinders. The ones on the bottom
 cylinders are a nightmare you have to lay down and
 work upwards. I used pallets to come up.
 Next time I will pull the cylinders. Then it will
 be a straight forward job without bleeding
 knuckles and cursing.
 Also remember that the o-rings on the intake
 manifold and cylinder base are 20+ years old.
 Next thing is to chose the right quality of hose.
 I did the mistake to by on the market. Everything
 was OK until I switched from the straight 100 to
 the ash dispersants oil W100 and winter time
 W15-50. It softened the rubber. Explanation was
 that the EU has forbidden some chemicals in the
 rubber doe to the cancer risk.
 So stick to the old good MS quality.
 Good Luck
 Paul
 Paul Pinato
 UC61A 43-14840
 SE-AWS
paul.pinato@swipnet.se
 Från:
fairchildclub@yahoogroups.com
 [mailto:
fairchildclub@yahoogroups.com] För Jp
 Lorie
 Skickat: den 31 augusti 2011 16:11
 Till:
 Ämne: [fairchildclub] Warrner165Qestion
 Hello good people,
     As my project is nearing completion I am going
 to replace the push-rod tube hoses, that is the 2"
 long hoses that connect the push-rod tube to the
 nipple on the engine. I am attempting to do this
 without removing the cylinders because the engine
 only has 115 hours since major overhaul. but the
 hoses are not young and healthy because, the
 overhaul was done 20+ years ago.  Do any of you
 have experience doing this hose change?  If so I
 am all ears! Please advise.
 JP.Lorie
 Florida
 [Non-text portions of this message have been
 removed]
