Fairchild 24 Vacuum Pump HELP
Posted: Tue May 31, 2011 8:10 pm
				'Ok I am trying to resolve a continuing problem with oil on the belly of my F-24.  Your help is greatly appreciated.  Before I wrote to this forum asking about a large amount of oil coming out of the crankcase breather and going all over the belly.  Since then I have sent the cylinders out to Harrison were they chromed (NUChrome) them back to standard, New Pistons and Rings.  Just flew it tonight for the first time.  Flew 25 minuets, landed and checked for leaks.  Still have a good amount of oil coming out of the breather and on the belly.  This may be the fact the cylinders are not broken in or something else.  My question to the group is who has a wet vacuum pump (pesco) setup on their 24?  If you do where do you have the oil return line coming from the air/oil separator return to the engine or oil tank?    Any ideas?  JON'
