Re: Ranger engine with Generator
Fairchild 24 Vacuum Pump HELP
'Ok I am trying to resolve a continuing problem with oil on the belly of my F-24.  Your help is greatly appreciated.  Before I wrote to this forum asking about a large amount of oil coming out of the crankcase breather and going all over the belly.  Since then I have sent the cylinders out to Harrison were they chromed (NUChrome) them back to standard, New Pistons and Rings.  Just flew it tonight for the first time.  Flew 25 minuets, landed and checked for leaks.  Still have a good amount of oil coming out of the breather and on the belly.  This may be the fact the cylinders are not broken in or something else.  My question to the group is who has a wet vacuum pump (pesco) setup on their 24?  If you do where do you have the oil return line coming from the air/oil separator return to the engine or oil tank?    Any ideas?  JON'
				WILLIAM SPRIGGS
Re: Fairchild 24 Vacuum Pump HELP
'Jon:  On my PT19 with wet Vacuum pump, the return line goes to the engine, next to tach drives.  Seems to work fine.  Bill Spriggs
Date: Wed, 1 Jun 2011 02:07:47 +0000
Subject: [fairchildclub] Fairchild 24 Vacuum Pump HELP
				Jonathan Martin
'Bill do you have an air oil seperator installed in the vacuum system or does the line go directly from the pump to the engine? Jon
>From: obliquephoto@comcast.net
>Yahoo! Groups Links
				WILLIAM SPRIGGS
'Jon:  I have an air-oil seperator and this drains to the engine.  It has to be mounted high on the firewall so will drain to engine.  Bill Spriggs
Date: Tue, 31 May 2011 23:06:34 -0400
Subject: RE: [fairchildclub] Fairchild 24 Vacuum Pump HELP
[Non-text portions of this message have been removed]'>
>Yahoo! Groups Links
'Jon, I have two air/oil separators One for the Engine and one for the wet pump, the return lines for both are routed back to the top of the oil tank.  I fabricated an aluminum tubing with two addition branches of small tubing welded to it.  also the same for the over board breather line.   The plumping is very creative becase of the lack of space.  It does and has worked good for me.
Ted Camp
N81326
Phone 248-688-8744
						Ted Camp
N81326
Phone 248-688-8744
				Jack Threadgill
'My Ranger engine in the PT-19 has a generator mounted on the upper rear
case. There is no oil seal in the adaptor plate on the generator pad nor on
the generator shaft. I am experiencing oil seeping out of the hole in the
bottom of the generator near where it mounts to the engine. Has anyone else
experienced this and have you found a cause or cure? I will appreciate any
info or suggestions.
Jack
Jack M. Threadgill
1602 Brook Hollow Dr
Bryan, Texas 77802
979-779-7155
threadgl@suddenlink.net'
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
				Airy Millet
'I have experienced such leakage, with original fiber-washer as oil catcher, and ZZ ball front bearing, replacing this bearing with rubber sealed lifelong gresed bearing.
But, still having leakage after some hours flight!
I ever tested, the fitting of a hose to the evacuation hole in order to collect oil drip and looking at the oil "consumption" from this leakage! This looks not to change things a lot anyway!
will be glad to ear of other solutions!
Airy
Date: Tue, 31 May 2011 22:22:44 -0500
Subject: RE: [fairchildclub] Ranger engine with Generator
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Airy
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
				jameslbryan@btopenworld.com
'Did they replace the valve guides Jon?
Sent: Wednesday, 1 June, 2011 4:20:43
Ted Camp
N81326
Phone 248-688-8744
Ted Camp
N81326
Phone 248-688-8744
				Jack Threadgill
'Airy, thanks for your report.  Hopefully someone has figured out how to
solve this. I have also considered tapping the hole in the bottom of the
generator and attaching a fitting with a hose out the bottom such as a
breather hose. The oil is going to get to the belly of the plane anyway,
but this would keep it off the back of the engine.
We welcome anyone's thought and info,
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
On Behalf Of Airy Millet
Sent: Wednesday, June 01, 2011 2:25 AM
To: fairchildlist
Airy
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Yahoo! Groups Links'
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
To: fairchildlist
Airy
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
