				warner 165
				Posted: Mon May 09, 2011 9:49 am
				by Jp Lorie
				'Does anyone know if the rubber hose that connects the push-rod tubes to the
 engine case can be replaced without pulling the cylinders off.
  JP.Lorie
 Florida
				SV: [fairchildclub] warner 165
				Posted: Mon May 09, 2011 10:22 am
				by paul pinato
				'Hi
 You have to unscrew the pushrod tube from the
 cylinder. On my engine it was very close. The
 pushrod tube can be hard to unscrew as the grip is
 so thin. It cost me two knuckles.
 Paul
 UC61A
 SE-AWS
 Från:
fairchildclub@yahoogroups.com
 [mailto:
fairchildclub@yahoogroups.com] För Jp
 Lorie
 Skickat: den 9 maj 2011 17:49
 Till:
 Ämne: [fairchildclub] warner 165
 cylinders off.
  JP.Lorie
 Florida
 removed]
