source for Fafnir KF4-A airframe bearings
Posted: Mon Jul 19, 2010 4:31 am
by shergei2001
'Does anyone know of a source for Fafnir KF4-A bearings used on control surfaces on PTs? They seem to be unavailable. While I plan to clean/repack most, there will likely some that should be replaced.
Pete Crawford'
Re: source for Fafnir KF4-A airframe bearings
Posted: Mon Jul 19, 2010 4:53 pm
by F.J. & D.A. Cox
'Would this help you get a little further down the road?
http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part=kf4&Brand=104&sessionid=&submit=Search&bhcp=1&sessionid=630420128822618758719201062157
Sent: Monday, July 19, 2010 11:31 AM
Subject: [fairchildclub] source for Fafnir KF4-A airframe bearings
Pete Crawford
Posted: Tue Jul 20, 2010 3:29 am
by Pete Crawford
'Frank,
Thanks a lot! That looks worth checking out. The only source I have found so far is www.locateballbearings.com and they want $99 each. Parts are in the UK of all places.
Pete Crawford
Sent: Monday, July 19, 2010 6:25 PM
Subject: Re: [fairchildclub] source for Fafnir KF4-A airframe bearings
Pete Crawford
Posted: Tue Jul 20, 2010 5:27 am
by Kevin Trumpore
'Pete,Try MSC industrial Supply, if they don't have it they can usually get it. Their paper catalog is larger than most city phone books, @ 4" thick. You can find them online, great people to deal with.
Kevin
Date: Tuesday, July 20, 2010, 5:28 AM
Frank,
Pete Crawford
Pete Crawford
Posted: Tue Jul 20, 2010 9:11 am
by OldOOwl@aol.com
'Could these bearings be the same as those used on the F24G? If so,
Univair has them but they are listed in the Stinson parts section...they cost
about $19.00 each...when I bought mine a few years ago.
Richard Hawley NC19105
In a message dated 7/20/2010 5:27:10 A.M. Mountain Daylight Time,
ketrumpore@yahoo.com writes:
Kevin
Frank,
Pete Crawford
_http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part
19201062157_
(http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part=kf4&Brand=104&sessionid=&submit=Search&bhcp=1&sessionid=630420
128822618758719201062157)
Pete Crawford
Posted: Tue Jul 20, 2010 5:01 pm
by Pete Crawford
'Thanks so much. I will give them a try too.
Pete
Sent: Tuesday, July 20, 2010 7:27 AM
Kevin
Frank,
Pete Crawford
Pete Crawford
Posted: Tue Jul 20, 2010 6:49 pm
by Pete Crawford
'Richard,
I looked in the Univair catalog and found Stinson bearings but can't tell if they are the same ones. I'll have to get some dimensions from them.
Pete Crawford
Sent: Tuesday, July 20, 2010 10:51 AM
Kevin
Frank,
Pete Crawford
19201062157_
Pete Crawford
Posted: Thu Jul 22, 2010 6:06 am
by mileslong2k
'A possible source for this bearing is a company, Banaire in Banning, California. They specialize in the AT-6 and BT-13 parts. They sell aircraft bearings applicable to these and other airplanes. They have a chart with photos, part numbers and bearing dimensions. It is listed in the, Aviation Surplus listing. There is a bearing listed, KP-4. Knowing how part numbers get changed from time to time possibly this could work. Hope this helps.
http://banaire.com'
Posted: Thu Jul 22, 2010 3:41 pm
by Pete Crawford
'Thanks Jim! It looks like have enough possibilities so I won't have to pay $99 each!
Pete
Sent: Thursday, July 22, 2010 8:06 AM
Subject: [fairchildclub] Re: source for Fafnir KF4-A airframe bearings
http://banaire.com
