'Does anyone know of a source for Fafnir KF4-A bearings used on control surfaces on PTs? They seem to be unavailable. While I plan to clean/repack most, there will likely some that should be replaced.
Pete Crawford'
Re: source for Fafnir KF4-A airframe bearings
'Would this help you get a little further down the road?
http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part=kf4&Brand=104&sessionid=&submit=Search&bhcp=1&sessionid=630420128822618758719201062157
Frank Cox
Frank Cox
Sent: Monday, July 19, 2010 11:31 AM
Subject: [fairchildclub] source for Fafnir KF4-A airframe bearings
Pete Crawford
'Frank,
Thanks a lot! That looks worth checking out. The only source I have found so far is www.locateballbearings.com and they want $99 each. Parts are in the UK of all places.
Pete Crawford
Pete Crawford
Sent: Monday, July 19, 2010 6:25 PM
Subject: Re: [fairchildclub] source for Fafnir KF4-A airframe bearings
Frank Cox
Pete Crawford
'Pete,Try MSC industrial Supply, if they don't have it they can usually get it. Their paper catalog is larger than most city phone books, @ 4" thick. You can find them online, great people to deal with.
Kevin
Kevin
Date: Tuesday, July 20, 2010, 5:28 AM
Frank,
Pete Crawford
Frank Cox
Pete Crawford
'Could these bearings be the same as those used on the F24G? If so,
Univair has them but they are listed in the Stinson parts section...they cost
about $19.00 each...when I bought mine a few years ago.
Richard Hawley NC19105
In a message dated 7/20/2010 5:27:10 A.M. Mountain Daylight Time,
ketrumpore@yahoo.com writes:
Kevin
To: _fairchildclub@yahoogroups.com_ (mailto:fairchildclub@yahoogroups.com)
Frank,
Pete Crawford
Kevin
Frank,
Pete Crawford
_http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part
19201062157_
(http://www.bearingsmatrix.com/bm/default.asp?pid=searchresults&stype=1&Part=kf4&Brand=104&sessionid=&submit=Search&bhcp=1&sessionid=630420
128822618758719201062157)
Frank Cox
Pete Crawford
'Thanks so much. I will give them a try too.
Pete
Pete
Sent: Tuesday, July 20, 2010 7:27 AM
Kevin
Frank,
Pete Crawford
Frank Cox
Pete Crawford
'Richard,
I looked in the Univair catalog and found Stinson bearings but can't tell if they are the same ones. I'll have to get some dimensions from them.
Pete Crawford
Pete Crawford
Sent: Tuesday, July 20, 2010 10:51 AM
Kevin
Frank,
Pete Crawford
19201062157_
Frank Cox
Pete Crawford
'A possible source for this bearing is a company, Banaire in Banning, California. They specialize in the AT-6 and BT-13 parts. They sell aircraft bearings applicable to these and other airplanes. They have a chart with photos, part numbers and bearing dimensions. It is listed in the, Aviation Surplus listing. There is a bearing listed, KP-4. Knowing how part numbers get changed from time to time possibly this could work. Hope this helps.
http://banaire.com'
http://banaire.com'
'Thanks Jim! It looks like have enough possibilities so I won't have to pay $99 each!
Pete
Pete
Sent: Thursday, July 22, 2010 8:06 AM
Subject: [fairchildclub] Re: source for Fafnir KF4-A airframe bearings
http://banaire.com
