'Don't forget, this is the minimum before take of...
of course, after long flight, the level can be quite low...
fairchildclub@yahoogroups.com
threadgl@suddenlink.net
Date: Thu, 12 Nov 2009 07:03:26 -0600
Subject: RE: [fairchildclub] Re: Ranger engine oil level
I read in a Ranger/PT-19 manual the bare min is 3 gal?s with normal
operating 3 ? to 4 gal?s.
Jack
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
On Behalf Of basinaviation
Sent: Wednesday, November 11, 2009 11:17 PM
Subject: [fairchildclub] Re: Ranger engine oil level
I keep mine about 3.5 gals. If I keep it topped off, it seems to blow out.
The bottom of the bevel of the spout for the oil filler cap seems to work
for me and minimizes excess oil on the airframe. I have the same issue with
cessna 172. It calls for 6-8 qts. If you fill to 8, it blows all over the
plane until it reaches 6qts. Fill it to 6, and it will stay there for a long
time with little blow-by.
Hope this helps.
Dave
--- In fairchildclub@
yahoogroups.com, "michaelmps" wrote:
> I am flying a PT-19 for a friend. What oil level do you find that works
best. When I bring it up to 4gal cold, it ends up everywhere. The owner says
he thinks it needs 4gal cold but I think that is wrong. He is old and dosn't
remember where the plane runs best.
> Save me again Fairchild club..
> Michael
Tchattez en direct en en vid?o avec vos amis !
http://www.windowslive.fr/messenger/
