F-24R 46 Baster Brake Kit info needed
Posted: Tue Oct 20, 2009 11:01 am
'I'm currently trying to rebuild the master brake cylinders on my 1946 F-24 project. The cylinder data plate identifies them as Wagner FE2014 Master brake cylinders. I've checked all the old Fairchild Club posts on Yahoo and purchased NAPA kit # 1 for the rebuild. I found the pistons in the kit were much longer and would not function properly in this application.
Is there another kit for these cylinders?
At least one of the cylinders will need to be sleeved so I will also need to identify what year, make and model car these cylinders were used on.
I found "White Post Restorations" (through the internet), will sleeve these cylinders with brass sleeves and complete the rebuild for $175 each. Are there any special instructions needed to pass on to them?
Are there any other shops recommended for this service?
Thanks for any help.
Rich Seifert
909-790-1320
Rich Seifert
909-790-1320
