Leaking strut
Posted: Tue Aug 18, 2009 6:50 pm
by John Ellis
'Good Evening
Does anyone know where to find how much oil should be in the struts of PT-19.
The plane is 125 miles from my shop with a strut leaking. I had them remove the cover and check the oil level on the dip stick.
Called back saying it was about half way up on the stick.
Thinking this may be problem, have never had one leak before.
Your help is appreciated,
John
Re: Leaking strut
Posted: Tue Aug 18, 2009 7:59 pm
by Steve Link
'Can you gauge it against the other strut that isn't leaking for a quick fix?
fairchildclub@yahoogroups.com
Sent: Tuesday, August 18, 2009 7:50 PM
Subject: [fairchildclub] Leaking strut
Good Evening
John
Re: Leaking strut
Posted: Wed Aug 19, 2009 9:32 pm
by basinaviation
'Hello John,
There should be a line scribed on the dipstick to show you a full indication. As far as the leak goes, my leak turned out to be from the gasket (or lack thereof) under the dipstick nut. It turned out when I landed, some fluid would push out the top and then run down the body of the strut.
I don't know where your leak is but it may be worth a quick look.
David Junker
541-331-7290
PT 19B
--- In
> From: John Ellis
> Good Evening
> John
