brake fluid
Posted: Tue Feb 26, 2008 12:35 pm
by Buhwana
'What is the popular fluid to use in the brake system for the PT-19.
The brake reservoir is about half full and the fluid is colorless but
doesn't smell the same as the Dot 3 fluid that is in the landing gear
struts. The Old Army maintenance CD calls it "hydraulic brake fluid"
bit it's not RED.
tom PT19
524JM'
Re: brake fluid
Posted: Tue Feb 26, 2008 1:42 pm
by Bob Haas
'If the stuff is real viscous and slick it may be DOT 5. I have
used this fluid for 10 years.
It is compatible with the seals and will not remove paint. Remember if you
change the fluid, pump
It in from the bleeder with an oil can. Will you be at Sun&Fun this year?
I'll be there to show and sell!
Bob Haas PT 19 N46199.
_____
On Behalf Of Buhwana
Sent: Tuesday, February 26, 2008 1:36 PM
Subject: [fairchildclub] brake fluid
bit it's not RED.
tom PT19
524JM
