'Keep em flying'
Steve Reber
'--- In fairchildclub@yahoogroups.com, Russell Williams wrote:
> I use the Poly Fiber process, but we were talking about metal coatings in the powder vs. paint discussion, not fabric topcoat.
> The Poly Fiber STC doesn't require a particular metal treatment the last time I looked, but does warn you that non-epoxy primers and varnishes will be attacked and will discolor the fabric when subjected to Poly solvents. I've used poly tack successfully directly atop the Poly epoxy primer, Poly epoxy varnish over wood, atop Deft 44GN11 epoxy primer on steel and aluminum, and atop primer + topcoat of Imron urethane. I've never tried Poly Tack atop powder coated material.
> From: stevearea58@...
> Date: Sun, 9 Dec 2012 18:18:22 +0000
> Subject: [fairchildclub] Re: advise
> Question
> 1, what STCed covering method are you using?
> 2, use the painting method required by the STC to remain legal
> Certificated aircraft require following the STC
> [Non-text portions of this message have been removed]
