are available in the States and therefore shipping might be less expensive for you. Try
Durafix or Alumiweld. Harbour freight sells the latter in small quantities and it sure looks like
my stuff. Search aluminum welding or aluminum brazing on Youtube to see how to do it. My stuff
works and I cannot speak for the others. alumibond.ca
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Tuesday, October 26, 2010 3:48 PM
Subject: Re: [fairchildclub] Grimes Type B Tail light
Cool, but what is the product name?
Sent: Tue, Oct 26, 2010 3:43 pm
Hugh, if it is an aluminum or white metal type material that needs repair, there's a product
out that will allow the home handyman to fix it with only a propane torch. It's brazing, not welding.
Stronger than original material, you can file it, drill it, chrome plate it etc.
Christavia C-FDWS
Sent: Tuesday, October 26, 2010 3:10 PM
Subject: RE: [fairchildclub] Grimes Type B Tail light
Thanks George, Avlite does have the complete light assembly but I wanted just the type B casting so I could build up a type B assembly using the parts from a type A light I have on hand. I have now located a type B casting, which requires weld repair, so I can put some sweat equity into it and have the unit I need. I'm happy with that unless some member has a unit which does not require weld repair. I would be interested in it.
Hugh L
--- On Tue, 10/26/10, Leighton, George wrote:
> From: Leighton, George
> Date: Tuesday, October 26, 2010, 2:18 PM
> Check with these guys they have everything Grimes
> http://www.avliteaviation.com/Product%20links/vintage.htm
> George
> ________________________________
> From: fairchildclub@yahoogroups.com
> [mailto:fairchildclub@yahoogroups.com]
> On Behalf Of Hugh Loewenhardt
> Sent: Monday, October 25, 2010 7:40 PM
> Subject: [fairchildclub] Grimes Type B Tail light
> I am in need of a type B (flanged) Grimes tail light for my
> restoration
> project. The condition of the light internals is not
> important as I have
> the internal parts. I need only the body casting. If any
> member has a
> light available for sale, please provide contact
> information.
> > Hugh Loewenhardt
> > What is the status of the project and how complete
> > the many parts?
> > Fritz
> > San Diego, CA. 92056
> > On Behalf Of BOB DUNN
> > Sent: Thursday, October 07, 2010 2:17 AM
> > Subject: RE: [fairchildclub] Looking for a PT19 or 26
> > project.
> > Nacogdoches, Texas North of Houston & SW of
> > Shreveport, Louisiana.
> > --- On Wed, 10/6/10, Fritz ;
> > wrote:
> > From: Fritz ; >
> > project.
> > Date: Wednesday, October 6, 2010, 11:08 PM
> > Your project sounds like interesting. I am in San
> Diego,
> > where are
> > you?
> > Sent: Wednesday, October 06, 2010 8:34 PM
> > Subject: Re: [fairchildclub] Looking for a PT19 or 26
> > project.
> > I have a PT-26 project I bought to rebuild for my
> best
> > friend to fly. We
> > were actually going to not use the canopy and make it
> like
> > a PT-19 so we
> > would have a pair to fly together. However, he was
> killed
> > while checking out
> > in a BT-13, so I've lost interest in the
> restoration.
> > Everything is off the fuselage which is ready for
> cleaning
> > priming/painting etc. the vertical stabilizer is
> ready. The
> > ailerons &
> > elevators are up through silver. The cover has been
> removed
> > from the center
> > section for cleaning, inspection & some
> rebuilding. I
> > have the wood ribs
> > already built for the cs. I was going to do a engine
> > tear-down and see what
> > it needs. Probable needs new rings...at least a top
> > overhaul and a good
> > cleaning & inspection. It came with a electric
> prop,
> > but I would have gone
> > back to a wood prop.The canopy is apart for cleaning,
> > painting and glass
> > replacement where needed. It has metal flaps and
> > floorboards, but no heater
> > installation. This could be added for cold climes.I
> am
> > asking $10,000.00 but
> > would allow $1,000.00 for transportation. You probably
> have
> > a good idea of
> > the size trailer and truck needed for transport. I
> believe
> > I have most all
> > the logs/paperwork. I wish the situation had been
> different
> > so my friend and
> > I could
> > have had "twin" PT's to fly.
> > Bob Dunn 936-564-7212 C-936-569-3287
> > --- On Wed, 10/6/10, stinsonman2000
> > wrote:
> > From: stinsonman2000
> > Subject: [fairchildclub] Looking for a PT19 or 26
> > project.
> > Date: Wednesday, October 6, 2010, 7:38 PM
> > Looking for a PT19 or 26 project. Prefer a complete
> plane
> > but will
> > consider what ever is available. I live in Pa. but am
> > willing to travel for
> > a good one.
> > [Non-text portions of this message have been removed]
> > Yahoo! Groups Links
> > Yahoo! Groups Links
> > http://groups.yahoo.com/group/fairchildclub/
> > Individual Email | Traditional
> > http://groups.yahoo.com/group/fairchildclub/join
> > (Yahoo! ID required)
> > fairchildclub-digest@yahoogroups.com
> > fairchildclub-fullfeatured@yahoogroups.com
> > fairchildclub-unsubscribe@yahoogroups.com
> > http://docs.yahoo.com/info/terms/
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3220 - Release Date: 10/26/10 06:34:00
