Here is the information from ATC-724 for the PT19:> I don't know if they do but I do know of a pair of
> skies for a P-19 and I
> would guess they are the same for both aircraft.
> Gene Haines
(a) Federal SC-4 (Maximum 2850 lb.)
(b) Federal A-2500 (maximum 2500 lb.),
Federal Installation Dwg. 11G264
(c) Federal A-2500A (Maximum 2500 lb.)
(d) Federal A-3500 (Maximum 3500 lb.),
(e) Federal A-3500A (Maximum 3500 lb.),
Here is the information from ATC-706 for the F24:
311. Skis (Eligible on any airplane of these models
provided the propeller installation meets the minimum
9 in. ground clearance. The maximum weight for the
skiplane will be the same as for the corresponding
landplane or that shown in parenthesis after each ski
model, whichever is less) Use actual wt. change
(a) Pollack P-3 (Maximum 2550 lbs.)
(b) Grab and Smith or Wien Alaska GS-5 (Maximum 3000
lbs.)
(c) Federal A-3500 (Maximum 3500 lbs.), Federal
Installation Dwg. 11G248
(d) Federal A-3500A (Maximum 3500 lbs.), Federal
Watch out for those double diamond slopes!
__________________________________________________
Do You Yahoo!?
Find a job, post your resume.
http://careers.yahoo.com'
