Sent from my iPhone
On Apr 10, 2016, at 9:57 PM, Michael Thomas michael_thomas8@yahoo.com [fairchildclub] wrote:
Like i said, all i need are the physical dimensions of the mounts he is making for the warners. Once i know that i can see if they are the same as the stc mount dimensions. Im not mounting a jake on a waco, it is mounting to a Fairchild 24w and the lord mounts the stc calls for are no longer made. Surely someone has take a set of calipers and measured them.
Thanks,Mike
Sent from my iPad
On Apr 10, 2016, at 18:30, 'Jamie Treat' jamietreat@q.com [fairchildclub] wrote:
Don’t know the setup. Need to follow the STC. Depends on the mount setup. The Jake setup on the Waco’s utilize bushings that are similar to Cont A-65/O-200 type. Just many of them for support. The Owl mount uses something very similar also. Much cheaper than the Warner bushings. JST From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Sent: Sunday, April 10, 2016 4:25 PM
Subject: Re: [fairchildclub] Price for new Warner motor mounts. Jamie, If you know the 'set up' for the Jacobs 'set up' why don't you pass the information on to Mike Thomas instead of just telling him 'it's different'. Any information is better than none. Knowledge is one thing a person give away (share) and it doesn't cost him anything. On Sunday, April 10, 2016 5:54 PM, "Jamie Treat jamietreat@q.com [fairchildclub]" wrote: Nope. Totally diff set up Sent via the Samsung Galaxy S® 4 mini ™, an AT&T 4G LTE smartphone -------- Original message --------From: "Michael Thomas michael_thomas8@yahoo.com [fairchildclub]" Date:04/10/2016 2:15 PM (GMT-07:00) To: fairchildclub@yahoogroups.com Cc: Subject: Re: [fairchildclub] Price for new Warner motor mounts. I have a 1940 24W but the Warner engine is not with it and instead I have an STC for a Jacobs 755 along with a three jake engines. My question is whether the warner mounts will work with the jake. Do you happen to know the dimentions of the mount? Length, girth, id of metal bushing? I suspicion that they will be the same as the stc drawing because in the end they still have to mount to the aircraft frame but before i order them i need to be certain. Thanks,Mike Thomas
Sent from my iPad
On Apr 10, 2016, at 11:27, hotfoot49@hotmail.com [fairchildclub] wrote: I forgot to put the pricce in my last post for the Warner mounts. Manfred has $87.50 each in his information to me. Keep 'em flying! Mike KellyFairhcild Club
